Set overlay position relative to element, not to page
  • January 4, 2022
  • 11 replies
  • 4894 views
RizePoint_Product
When creating overlays, there are cases when I want it to be positioned relative to the element that triggered it. For example, a tooltip that explains a button or image.
Currently the only way to do that is to manually position the overlay. What would be nice/more efficient is to have an option to choose how I want the position to be calculated-- relative to the entire page, or relative to the element itself–with the same set of position options (centered, top left, top right, etc) that we currently have for alignment. That way overlay positions can be set quickly without the need for manual fiddling.
Christoph_Wolf
yeah (bump)
  • March 4, 2022
Natti
  • November 1, 2023
Continuing the discussion from Set overlay position relative to element, not to page:
The Problem:
There are similar posts about this but most are closed by now, the problem is when using Open overlay interactions I often use the Manual positioning for menus and as the prototype grows I may have several menus that I have to manually move into the desired position.
Screenshot 2023-11-01 at 11.46.57 AM
The Proposal
It would be very useful and time saving to be able to set the overlay position relative to the element rather than the page. Currently you can set basic positions like top right bottom center etc. but that’s for placement on the screen thus not particularly helpful for things like menus.
I would like to set the position top left or bottom right of the element that triggered the overlay, something like the following:
There could be more options to account for center positioning as well and we should be able to set if it needs to sit inside or outside the element (bottom left / outside for instance). Another way possibly, as a workaround could be to allow setting of default locations say if I set an overlay to the bottom right of an element the next time I select Manual positioning for an overlay it defaults to the bottom right?
Perhaps this is another ticket but the bigger issue is how main components treat the overlay interaction in that they are not inherited and persisted by the component’s instance. Even if/when the instances retains the overlay interaction, there’s no way to set different interactions directly on the resulting overlay, so the initial problem noted in this request would still exist.
Any help or update to this would be greatly appreciated, I know I’m not the only one experiencing this and it would lead to a much improved workflow, thanks!
  • November 3, 2023
Thanks for the feedback!
We’ll pass this onto our team for consideration.
Desislava_Slavkova
+1 This would have solved so easily my component that needs tooltip… Now I have to place manually…
OG_Can
  • July 15, 2024
This can be a serious pain point when designing prototypes with tooltips or overlays or when mimicking framework behavior like Bootstrap. It is especially true when you introduce multiple viewports through variables that affect the auto layout positions but not overlay positions.
Relative to page vs relative to component would be a great improvement.
Gerard_Pamies
Exactly the same problem. I need tooltips and the component is not a solution because the z-position of the tooltips can not be controlled globally (which would be a more elegant solution). Since I’m using overlays as a workaround, being able to position the overlay relatively to the trigger element instead of the page could speed up the work.
I found a workaround. Using a hover event in the component set to a component that has a tooltip as an absolute position outside of the trigger element. Then when using this trigger component be sure in autolayout to use “First on top” as a setting in the top container and avoid the “Clip content” checkbox so the tooltip is not cropped and appears on top of the next elements.
Lachlan1
  • October 24, 2024
This is a sorely needed feature for creating prototypes using components and is one of the biggest time wasters for our team when prototyping.
Sick of having to detach components which makes updates a tedious process, creating silly pseudo components that don’t play nice with our design libraries, and having to prototype from multiple component instances instead of being able to do so from the main component… you know, like how components are meant to work.
Giving the option to set overlay position relative to component would fix all of this.
Julia_Shlyapnikova
Yes please. Unlike frame-relative orientations, the manual option cannot be adjusted for multiple interactions at once, which is a huge pain.
MNCreations
  • August 19, 2025
+1 this. It would make overlays a million times more useful. Also, an option for whether elements outside the overlay are clickable or not would be really helpful. (right now while an overlay is open, anything outside it is not clickable.)
Albert Nimtz
  • May 28, 2026
I have to manually move dozens of overlays every time I create designs. We have a lot of dropdowns and overlay menus, this would be a highly useful DX / UX feature!
