Request for Essential Figma Shortcuts: "Hug content", "Fill container" and "Fixed width"
Ulya
Hey Figma Community!
I wanted to suggest adding keyboard shortcuts for “Hug content”, “Fill container” and “Fixed width”.
With the new design, these options are now in a dropdown, and having shortcuts would save so much time—potentially making our workflow 30% faster!
Imagine using these shortcuts on Figma Creator Micro or other external keyboards—how cool would that be? If you agree, please like this post so Figma can see the demand and implement this feature.
Thanks for your support!
Roman_Lisnichy
I am also waiting for this shortcut! It will significantly increase the speed of work.
Raphael_Guilleminot
There’s a little known shortcut for this. Holding down OPTION or COMMAND & double clicking the edge of the selection will apply fill or hug, respectively.
screenshot-Figma-000636
Note to Figma devs: for some reason, this trick works on multiple selections for FILL (holding down OPTION + CLICK), but does NOT work for multiple selections for HUG (holding down COMMAND + CLICK). Please fix !
EDIT - There’s another way to add the shortcut for this. You can save the Auto Layout Shortcuts plugin. This will add a bunch of commands to your app menu, which you can assign to a keyboard shortcut via MacOS Keyboard shortcuts in Settings.
Ulya
  • 4 replies
  • July 25, 2024
Thank you for your comment! But in the 1st case it’s not convenient when you have a super long item and you have to look for a corner to do this. Additionally, if you have a lot children in your main auto layout it may be difficult too.
And regarding the shortcuts in menu-I think it’s anyway an additional step, to press command p, run plugin and select hug content or fill container
Could you please share your experience of how you usually use auto layouts? Like pressing each time on the interface button?
Maksym_Bocharov
Yes, I am also waiting for these shortcuts! All designers I know work with auto layout every day but with shortcuts work will be faster!
Ulya
  • 4 replies
  • July 25, 2024
Thanks for your support! Definitely! 👁️
  • 4946 replies
  • July 25, 2024
Hey All, thanks for the feedback!
We’ll pass this onto the team for future consideration. And thank you to @Raphael_Guilleminot for providing temporary alternatives. 🙂
Raphael_Guilleminot
@Ulya I don’t think you understood my recommendation. In Mac OS Keyboard shortcut settings, you can spell out the full menu path to a menu command and assign a shortcut to it. If you SAVE a plugin, it will be available in your mac app menu bar. You just have to manually write out the full path of the command using-> to target a command located in a sub-menu. Be careful, it’s case sensitive.
In this case, I used
Plugins->Saved plugins->Auto Layout Shortcuts->Horizontal sizing->Fixed
width
Ulya
  • 4 replies
  • July 26, 2024
AH, I got it! Just tried it, but for some reason, shortcuts do not appear in my plugin (saved) as you showed in the screenshot.
Really appreciate your help!
UPD IT WORKS! You’re the best!!!
Raphael_Guilleminot
@Ulya Good news, it’s now a native Figma command that you can assign a shortcut too. I thought of you.
Ulya
  • 4 replies
  • October 20, 2024
UPD: I changed the path according to this: ahahahah
Hey @Raphael_Guilleminot ! thanks! ohhh I cant do it again. when I set a shortcut for “Actions…” it works (Basically command+K). But when then I add “Set width to hug contents” - it does not work anymore. So the command:
Actions...->Set width to hug contents
Doesn’t work…
Maybe you know how to solve it?
Thank you
Jerry_Jappinen
People have been eagerly waiting for this shortcut for years. Happy to see we have menu options now, but browser users cannot set custom shortcuts from macOS keyboard settings.
Considering how essential auto layout has become, I think it’s time to introduce default shortcut for at least hug/fill width!
NOTE: if you want to change from hug/fill to fixed width, you can do this with nudging width/height back and forth quickly: first CMD+LEFT (subtracts 1px from width/height and changes it to fixed) and then CMD+RIGHT immediately after (add 1px back).
Metin Saray
  • February 23, 2025
How do you assign a shortcut, because Figma itself did not give these functions a some key combinations for us to trigger them via a Mouse or a third party app?
antler-hat
  • 5 replies
  • July 14, 2025
It’s not the same thing, but I made this plugin to enable more keyboard control, which is kind of like opening up a whole bunch more shortcuts
Fill and hug width/height short codes are included
https://www.figma.com/community/plugin/1510266761765016786/lazer
Keyboard shortcuts are crucial for speed and efficiency, but Figma offers a pretty limited set and you can't customize them.
Lazer proposes a decent workaround inspired by command line interfaces. It includes a number of common adjustments, each with a short code (see below). When you bring up the Actions input with command + K or command + / and then type a shortcode (eg. w.h), the fuzzy search will be ready to select that action.
