Replacing text and images in bulk
  • January 9, 2024
  • 1842 views
I have over 40 web banners and I want to swap out and replace with a new image. How can I do this
without having to do it one at a time?
The same apply’s with text. Can I update text on one frame and have it applied to all the other banners?
Best answer by Celine_
Hey Tom,
To replace images in bulk, I’d recommend you to select all images with the keyboard “SHIFT”, then editing them in a bulk in the image setting in the right design panel.
And, to edit text in a bulk, as a workaround, you can use the search bar in the left panel to find your text, select all of them, then edit them in bulk in the design panel.
Hope this helps!
Celine_
  • 3680 replies
  • January 10, 2024
Hey Tom,
Hope this helps!
