Pixelated image when exporting
Vincent2
Hello
I have to export a lot of assets for a client, can be several thousands. I noticed that when exporting, some assets still have that pixelated rendering that looks like progressive JPG. I’m quite sure this is because when exporting, Figma hasn’t finished loading all the HighRed images. So I tried scrolling through all my images at more than 100% zoom and waited for Figma to load the complete image when it wasn’t. Did that through all my assets, launched export, and it still had that pixelation on some of them. I think by the time I had scrolled through all my images, Figma just decided to go back to low res for some of them, which is not very nice… Do you guys have any idea how I could resolve this?
Thanks
Best answer by Celine_
Hey Mark,
The assets altogether shouldn’t exceed 4096 pixels in either direction. If either the x or y dimensions exceed 4096, Figma will resize the entire object proportionally to keep it within this range. Hope this clarifies!
(Also for visibility, I check on our backend on Vincent2’s case, here the response from our support team: this behavior is expected — the reason for the pixelation is because you’re hitting the browser tab memory limit, causing some exports to be “cut short”. Exporting chunks is the solution here, as is splitting your file up so you’re not exporting too much at one time to begin with.
This is a browser limitation, similar to a memory file limit, and isn’t something that Figma can’t alter at this time. )
Celine_
  • 3743 replies
  • June 9, 2023
Hi @Vincent2 ,
Can you please try these steps to see if that helps?
It’s possible that the low resolution images were caused by a compression setting in Figma during the export process. To ensure that all images are exported at their maximum resolution, you can try the following steps: Select all frames and go to the Export panel. In the Export panel, choose the JPG file format and set the export resolution to “Original”. Check the “Export all” checkbox to export all selected frames. Choose a destination folder and export your images. This should export all i…
If you are still running into issue, would you mind reaching out to our support team so they can take a closer look? If you could share examples and/or file access that would be super helpful! Here’s the form
Vincent2
  • 7 replies
  • June 9, 2023
Hey, thanks for the help. I already contacted the support but they didn’t help yet, I contacted them yesterday so I can wait a few days. When it says the export panel, are they talking about the export panel where you set the export settings? Or the export panel that popups when you hit “export”? Anyway, I don’t find all the options they talk about in both of them. Attached print screens of what options I can find in both of them.
Celine_
  • 3743 replies
  • June 9, 2023
Thanks for the information, our team will reply you soon. As you have sent your file, our team will try to replicate and will be able to investigate further.
You are right, after double check, this option doesn’t appear on my side! Sorry for the misunderstanding.
In the meantime, here another tip: we generally recommend exporting your designs at a larger multiplier (2x) to create higher resolution exports and reduce blurry exports. You can read more here about the different export formats and settings we offer.
Hope it helps!
Vincent2
  • 7 replies
  • June 9, 2023
No worries, yes I’ll wait on them. Yes I know, I use to export at retina and non-retina for bitmap assets, but the issue is not about quality. I’m quite sure it has to do with progressive loading of the image because I can clearly a larger than the actual pixel grid of the image in the image. I’m pretty sur it has to do with Figma not loading the complete image data before exporting.
Hello, I’m noticing the same issue. As Vincent2 says, I also believe it has to do with compression and progressive loading of the image. It’s urgent to solve this, as when I export images for social media (although that’s not the main goal of Figma) they are pixelated. Please get back to us ASAP. Thank you.
  • November 16, 2023
I’m also having this challenge. When will this be fixed?
  • November 27, 2023
I’m also running into this issue. Does anybody have a fix?
Taha_Paracha
Hey, I had this same issue, but when exporting, I used @celine_figma’s advice and used x3 or x4 and it now looks great! Thank you.
wonjun4862
It’s double work but you could do Figma → pdf → jpg/png and adjust the ppi during the second step. For some reason only the pdf file seems to capture the full resolution when exported. It would be nice if we wouldn’t have to, but “where there’s a will there’s a way” I guess!
marehovv
  • January 24, 2024
I have the same issue. I exported as PDF then converted to png, which worked but took loads more time.
Manu_M2
  • January 30, 2024
great, that fixed it for me too
thanks!
marehovv
  • February 29, 2024
This is also coming out blurry for me, unless I export as a PDF. I submitted an issue.
same problem for me. When I export in PDF or SVG all good, no pixelation. When I export in png and jpeg it’s pixelated even in x4. I moved the images to a new blank workspace to see if it was a loading issue. What’s the deal?
I also have this issue, and we are so close to launch…
This is so stressful! 😦
Mark_Anderson2
I’ve tried all the methods mentioned here with similar results. The odd thing is this, I exported a large 1440 X 1000 frame (case study thumbnail) and it is in perfect hi-res. But when I export a 390X4822 frame I get lo-res pixelation. Even if I go the PD\F etc workaround when I import it into Figma it is still the same poor quality.
So, I did a little copy and paste from my full iPhone frame into the stock 390 X 844 frame, exported that as 4X PNG, and imported it into my case study with perfect resolution. Back in December I did not have this issue and exported frames at 390 X 4008 with no issues. So, what is the exact frame size limitation to avoid this issue? And will it be resolved any time soon?
Thanks.
Celine_
  • 3743 replies
  • March 21, 2024
Hey Mark,
johntk22
  • 11 replies
  • March 21, 2024
Instead of exporting all the images at one time, consider exporting them in small batches. This can help in reduce the load on Figma and ensure all images are export successfully.
Pierre_Hatier
Hi,
I have the same issue here, any new solutions yet?
Or updates about when this problem will be fixed @Celine_Figma ?
Many thanks
Celine_
  • 3743 replies
  • May 13, 2024
Hi @Pierre_Hatier , as reminder you may encounter this issue of pixelation because you’re hitting the browser tab memory limit, causing some exports to be “cut short”. Exporting chunks is the solution here, as is splitting your file up so you’re not exporting too much at one time to begin with. This is a browser limitation, similar to a memory file limit, and isn’t something that Figma can’t alter at this time.
As explained, we generally recommend exporting your designs at a larger multiplier (2x) to create higher resolution exports and reduce blurry exports. Or, exporting your images in small batches as @johntk22 explained. You can read more here about the different export formats and settings we offer.
If you are still running into issue , we would like our support team to take a closer look at your issue, please reach out to our support team with a link of your file directly: Here’s the form
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as en Editor, so we can take a closer look. Thank you for your help!
Pierre_Hatier
Hi @Celine_Figma, I understand that this can be a browser tab memory limit. Nevertheless, the memory usage of my file is 4% only, and the element I want to export is only a 970x250px banner. In this case, shouldn’t the export work fine?
Celine_
  • 3743 replies
  • May 13, 2024
Thanks for the information! Yes, it should be. Still, it’s difficult to know the root cause without investigating your file. I’d recommend you to reach out directly to the support team so they can try to replicate: here (Please also mention the banner you want to export) Thank you!
Pierre_Hatier
I’ll do that then, thank you!
Hello,
New Figma user, just encountered this issue, you need to make sure the coordinates X,Y of your assets are integers (no decimals 250 not 250.5).
Hope it helps.
luis_jaky
Hello,
I understand your frustration with the pixelation issue you’re experiencing when exporting assets from Figma. It can be quite frustrating when the quality of the images doesn’t meet expectations, especially when working on a large project for a client.
One suggestion I have is to try exporting the assets individually or in smaller batches rather than all at once. This way, Figma may have more time to load the high-resolution images properly without compromising quality. Additionally, double-checking your export settings to ensure that you’re exporting the images at the highest resolution possible may also help alleviate the issue.
Another option to consider is using alternative design tools or plugins that may offer more reliable export capabilities for high-resolution images.
In the meantime, if you’re in need of high-quality PNG images for your projects, I highly recommend checking out PNGsHub.com. It’s a fantastic resource for finding a wide variety of stunning images that can enhance your designs and ensure a professional finish.
Best of luck resolving the pixelation issue, and don’t hesitate to reach out if you need further assistance!
  • August 9, 2024
Hello! I may have found a solution. I was trying to export a logo I made in Figma and it was pixelated. So, I went to zoom function, now located on top right side, after they moved it (grrr), and changed to 1x or 2x. Exported as PDF as recommended. Then went to Finder on Mac. and double-clicked to convert to PNG as recommended. Clicked on File and Export as png which revealed pixels at 65/per inch. I changed to 300, as recommended, and it worked. However, The circle the logo is in was slightly larger than the crop box. I may go back to Figma drawing board to fix this issue, but right now, and 2 hrs later, I can live with it.
