No prompt to sync library updates
Since yesterday evening, after I publish library updates, I am not prompted to update the components in the file where the library is available. I also don’t see the updates when going to libraries → updates. If I close and reopen Figma, the update prompt appears instantly.
Best answer by Celine_
Hi there! Thank you for flagging this. Our team is aware of this issue and has implemented a fix.
Please refresh your browser / the app in order to see the fix.
And, please let us know if you still encounter any issues!
Celine_
  • 3529 replies
  • September 27, 2023
It seems to be fixed now. 🙏
Stefan2
  • October 25, 2023
Yeah … this issue is still persistent on some of the files (not all of them). Would be nice for this to be fixed properly. Really annoying.
The only fix I could find is copy/paste from library to the file, but event the new copies don’t update properly if I make any changes in the library.
Pat5
  • 9 replies
  • November 6, 2023
Libraries syncing is getting worse and having a huge impact productivity. In the design file I can see updates available (sometimes), yet I can’t click to preview changes (loading spinner from hell), I click on the update and the component in the file is still not updating. I spend so much time trying to fix the issues that its becoming ridiculous.
Hi there! I have the same issue for several weeks now. We use several library files and several files linked to them and no matter where I make an update, the update doesnt come up in the file referenced to. The only fix is to restart the file, then the message comes up. The problem only occurs in my desktop app, all other team members using the same files dont get into this.
Is there another solution for fixing that problem?
Celine_
  • 3529 replies
  • November 24, 2023
Heu Philipp! Sorry to hear you are having issue. Please reach to our support team so they can investigate further, as these can be related to another issue here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
Andrew_Mowe
  • 6 replies
  • November 29, 2023
I’m still seeing this issue as well. I have seen it using three different libraries and many different files. I have to close and reopen all files to get the component update prompt. I am running the latest version of Figma Desktop ( v116.15.4)
Madory
  • 4 replies
  • December 4, 2023
Same issue here for months, very annoying…
Celine_
  • 3529 replies
  • December 4, 2023
Hi everyone,
As a workaround, can you please try to clear out the cache to see if that helps? Please follow the steps for the browser and desktop app here: https://help.figma.com/hc/en-us/articles/360040328553-Use-Figma-while-offline#clear-data
If this doesn’t help, I’d recommend you to reach out directly to the support team: https://help.figma.com/hc/en-us/requests/new. They can investigate what is causing this.
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com, so we can take a closer look. It may also be helpful if you can also share a screen recording of the issue so we can take a look at what you’re seeing when publishing updates and then trying to receive them on another file. Thank you!
Jim_Muirhead2
  • 5 replies
  • December 8, 2023
Clearing the cache in the Figma desktop app fixed things. Now I just have to see how long the fix sticks for.
Jim_Muirhead2
  • 5 replies
  • December 8, 2023
Oops! That didn’t last long. Back to no alerts for component updates.
Amico
  • December 12, 2023
I’m experiencing the same issue. Not all files get the prompt to update the library which is hugely time consuming since it’s something I do maybe 100 times a day…
I tried re-install Figma and duplicating the file but the prompt won’t show up
Maciej_Bieganski
Same here 😕
Sean_Pyne-Moran
I have the same issue, need to constantly reload the tab to get publish updates from the library file.
Miriam
  • December 18, 2023
I still have the same issue… I’ve had this for months, but now is getting worse, before was enough to close and open the tab file, but now I have to restart the whole Figma app to get the update, really annoying.
At least, if it is not prompting automatically, would it be nice if we had a button where we could click to kind of “force a double check if there are updated” functionality or something like that…
  • 13 replies
  • December 18, 2023
I’m having this same issue, it worked fine untill last week. I just created a topic for this issue today when I came across this thread. My topic:
Older files still update libraries with displaying the dialog box every time, but newer files won’t displays the dialog box. It shows it once, after startup, but from then on I need to update components manually… It’s workflows hell for me.
I wish I just could set it to update automatically.
Jakub1
  • 4 replies
  • January 8, 2024
Same here, update dialog is not consistent. Sometimes I see it, sometimes not. Without it I have to click on each component to update it 1 by 1 which really impacts productivity and creates inconsistencies.
Andrew_Mowe
  • 6 replies
  • January 8, 2024
My team has been seeing this behavior intermittently for months as well. I thought it had been resolved but I’ve heard new reports this past week.
Joana_Vieira
I have the same problem for a couple of weeks now. The library updates notification just simply stopped showing on all files. I have to manually update it by going to the Assets tab, and clicking the library button.
pequ_dev
  • January 11, 2024
Please, some of us builds serious business using your tools, and you are ignoring a critical problem because there is no competing product on the market with similar functionality.
However, one day one will emerge, and then users who let their customers down will remember it…
Is it so difficult to audit your code base, whilst Figma market evaluation exceeds $10 billion?
Celine_
  • 3529 replies
  • January 11, 2024
Hi everyone! We understand your concern, and sorry for the trouble. The prior issue has been fixed on 28 September, so we need to investigate further your issue to check if it’s related to another issue or not.
As explained, please reach out directly to the support team with a copy of your file here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you! 🙏
Alec_Danz
Hi @Celine_Figma Is there another thread to follow? I’m experiencing similar issues with our libraries.
ksn
  • 1653 replies
  • February 12, 2024
@Alec_Danz Stepping for Céline here.
Library issues are [usually] specific to the library itself, so these kinds of issues are difficult to address on the forum. We’d need to look at the files/libraries themselves to get an idea of what we’d recommend [or find any bugs that are hiding].
For anyone that visits this topic, I’d recommend reaching out to support by either emailing support@figma.com, or filling out this form.
Also, a note for everyone: please do not post links or screenshots of your files, or post any personally identifying [like your email address] here. We will not be able to take any action other than to redact this info from the forum. Appreciate your time and patience 🙏
Oren_Horev
Seeing the same issue here. Initially thought it is because of bad component properties but looks like it’s not related
  • 4 replies
  • March 19, 2024
I am experiencing the same issue. Latest Figma Pro update: version 116.17.11
