Nested autolayout height
Rachel_Sweet
When using multiple nested layers of autolayout (use case: expandable table rows inside expandable sections on a page), the height of each nested variant doesn’t dynamically change when variants of different heights are swapped. The nested frame of components (with autolayout applied) just get stuck at the initial height. If I pull the nested frame outside of its parent auto-layout frame, it works as expected.
Pavel_Kiselev
First thing to check is nested instances height settings. Is it hug contents? This this the only way to get dynamic height on swappable instances
  • August 18, 2023
