LAUNCHED: Moving or copying variables
Anton_Bahrencheer
Has anyone found a way to copy, transfer or move the new local variables to another file or collection?
Just created around 400 color variables manually in the wrong file and would hate having to re-create them in the correct one 😅
Equinusocio
It seems SHIFT + Enter does the trick after selecting a variable.
Anton_Bahrencheer
Awesome shortcut for duplication, will save some time for sure! 😃
You haven’t found a way to transfer the variables to another file though right?
Richard_Simms
I had the same question and found this:
Copy pasting variables across files
Variables can be used in prototypes.
Currently, if you copy and paste objects to different file, the prototype will continue to work as the variables transfer over. However, any unpublishedvariables applied to prototypes won’t be available for further use, like when creating Set variable actions, or switching an object’s number variable.
We are working on improving transferring variables across files. As a workaround, either recreate the variables in the destination file, or duplicate the original file.
If the original file is published to team libraries, copied and pasted variables will work as expected.
If you receive a notification that pasting unpublished variables across files won’t create new local variables yet, try publishing the source library and and enabling it in the destination file.
Figma Help Center
Anton_Bahrencheer
Ahh bummer, will have to go manual again then, thanks for finding this! 🙂 Hope they add the feature soon 🤞
Yejin_Park_Private
Has this feature been added yet? I’ve also made a mistake of generating 100+ variables in a file that I originally intended to delete 😦
I was able to publish this file to use the variables in the correct design system file, but I’d hate to leave the wrong file in my pj folder just because I need to use it as a variables library. Is there really no other way to move these variables to the file I want…?
owen5
  • 8 replies
  • June 30, 2023
In addition to moving variables from one file to another, I’d also like to have a way to copy aliases and variables within a file. For example, I have 10 variables across 2 modes which all need to have the same alias applied to them. The current workflow requires that I manually assign an alias every time, instead of copying an alias from an existing variable.
Sorin_Jurcut
I managed to find a workaround by exporting them as json and importing them back via the same JSON
For export I use this plugin: https://www.figma.com/community/plugin/1254848311152928301
For import I use this one:
Figma
As a caveat for the second plugin, be aware you’ll need to perform some cleanup work post-export. Not a huge deal, but a bit annoying.
If you are going to use the import from the first plugin, it will give you a range exception and you’ll have to reload the file. Just be aware of that !
Erich_Quist
thanks dude.
I can’t make it work with Variables Export/import, even though I copy the code into a JSON-file. I get error messages when trying to import the file with Vaiables import and also when pasting the code in the window in the Variables Imoprt/Export plugin.
Elham_Mahootchi
Doesn’t work for me either. When I click try to Export the Variable Collection, nothing happens. I can see them as codes and I can see the blue Export Variable CTA but nothing happens when I click on it 😦
Elham_Mahootchi
Hey there! I used this for my colour variable collection and it worked. My project was a website with dark and light mode and I had created the colour variable collection on the Design System file (let’s call it file A). In order to use it on my prototype file (file B), I tried to look for a way to transfer the variables so that I could see what colour in the light mode is equivalent to the one on the dark mode.
Since the variables are not sharable like libraries, I looked into different solutions and here’s what I found:
When you create a set of colour variables, it’s usually saved as local library. (you can see them in Libraries under Local colours). So I published my local library of file A, and used it on as a library on file B. Although it didn’t show me the colour equivalencies as a table, I still could find the equivalent colours by switching between light and dark mode on my file B.
Hope it helps 🙂
Elizaveta_Klevakina
This plugin did it for me for 5 seconds:
Figma
Stephane_Popout
@Richard_Simms I built a plugin to restore variables used in a prototype and relink them on your new file
here is the tutorial post about:
Nathan23
  • October 18, 2023
The export/import function of this plugin is amazing!
rex5
  • November 16, 2023
Found another free plugin:
Figma
Stephane_Popout
I just updated my plugin to move your variables and you can now select the variables you want to move and it will take all the depending variables and copy them to your new file.
I created a small tutorial video for it (4mins), I hope it will help you
In case of any additional questions or desired improvements, don’t hesitate to let me know on the plugin page or here
If you like the plugin and find it useful please feel free to give it a like and share it 🤗 !
Oliver_Schwaiger
Did try a different approach and faced a weird break in detaching patterns within Figma.
–– When I wanted to get rid of color styles, I had to …
  1. Reference the color variable as value of the style
  2. Publish changes and pull into all files
  3. Delete the styles → they automatically detach and the value (color variable) is set instead.
  4. So the mechanic of detaching to me seems to follow the rule:
    the element I detach is maintaining all the information that sits inside of it and gets only diconnected from it’s selected level.
–– When detaching a component
  1. All items used inside the component itself will remain same
  2. To me again it seems like the same rule applies:
–– However, when I try to move a variable between files using this detaching logic, the pattern breaks, and I am wondering why? …
  1. Link the color variable (e.g. of a different library Foundation/Primitives) as value of the previous variable (because it sits in the wrong file, but is connected to lots of different files)
  3. Delete the variable (from the file I initially want to move it from)
    → assumption based on patternit will automatically detach and the value (color variable of the foundations file) is set instead, but…
    → it detaches also the referenced color variable and only the hex value is shown, …
    WHY??
Bencko_Jan
@Elham_Mahootchi Copy the Export code you see to the clipboard, then go to the Figma where you need to import the variables and paste the code into the Import code textarea and click Import. Magic done. Hope it helps 🙂
Hal_Lee
  • 16 replies
  • January 9, 2024
I just created a plugin that allows you to copy and paste variables between different collections or files. You can also export variables as JSON and import it as another collection. All properties like scoping and code syntax will be remained.
Figma
Ayko_Neil_Kehl
Exactly what I needed! Worked perfectly.
Oliver_Schwaiger
Thanks @Bencko_Jan & @Hal_Lee.
Quick question as I do not only want to copy and paste variables between files, It is super important for me that all linked variables in all files will stay synced with the variables. Not to create another copy of them.
Is this something that your plugin can do? Then I would love to try it out. But as I am working on a library connected to tons of files, I have to be very careful.
Bencko_Jan
Maybe just create a new Design system containing the variables you need and connect that design system to the files where you need to need to use the variables.
Bencko_Jan
Oliver_Schwaiger
Thought about that already if you mean Figma libraries. But it feels like a rather messy approach to me.
Hal_Lee
  • 16 replies
  • January 11, 2024
I found this plugin that can replace variables but you need to replace one by one.
Figma
I plan to support swapping variables by variables matched in my plugin later.
