Issue with text alignment
  • December 15, 2021
  • 8 replies
  • 3364 views
Matt_Holihan
Hi,
I’m having issue with text alignment. I have created a component with text that is within an auto layout. The text itself is left-aligned and the auto layout is aligned to the top left. However when using the component and editing the text it fills from the centre.
Screen Shot 2021-12-15 at 2.28.44 pm
Best answer by Gleb
Set constraints to Left.
Matt_Holihan
Example of a label with extended text
Example 2
  • 4707 replies
  • December 15, 2021
Without seeing how your constraints and layers are set up, there can be millions of reasons why it would work this way.
Matt_Holihan
I’ve noticed the issue happens once I make it a component. Before doing so, the text within the auto layout stays left aligned.
Matt_Holihan
Here is a screenshot of the auto layout setup
Screen Shot 2021-12-15 at 4.26.38 pm
Matt_Holihan
… and a screenshot of the text setup
Screen Shot 2021-12-15 at 4.26.51 pm
  • 4707 replies
  • December 15, 2021
Matt_Holihan
That did the trick. Thank you.
  • January 14, 2022
