Is there any way to enable “Spread” option under drop shadow for a flatten vector?
  • September 20, 2022
  • 7 replies
  • 3829 views
daken
  • 26 replies
When I flatten a vector, the “Spread” option under drop shadow will be disabled.
Is there any other way to hack or enable this option under drop-shadow?
Best answer by AlicePackard
@daken spread for shadows can only be edited when the frame you’re working with has a fill. I’ve found success applying a fill and setting the opacity of the fill to 0.0001 (which will register as 0 in the input, and effectively invisible on the canvas). You also must make sure “clip contents” is turned on.
Here is a GIF demoing how to do this in Figma:
spread
And also Figma’s documentation on drop shadow spread.
daken
  • 26 replies
  • October 30, 2022
Timj
  • 82 replies
  • October 30, 2022
Shadow spread is only supported on rectangles, ellipses, frames, and components.
Did you try making it a component?
daken
  • 26 replies
  • November 15, 2022
still doesn’t work 🥲
shrey
  • December 1, 2022
I don’t think there is a way around this constraint, but one hack I’ve found is to duplicate the vector and use “layer blur” effect to emulate the spread parameter.
AlicePackard
spread
daken
  • 26 replies
  • June 19, 2023
that is great
Wes_Gehbauer
The component/frame etc. needs to have the “clip content” checkbox selected in the Frame section in the design control panel (top left of the screen) in order to apply a spread to a dropshadow
