Improve Plugins navigation
Alexiss
Hi all, I plan to develop a plugin to give the possibility to navigate more easily between plugins.
Is it something you could use or not?
Something like this?
Thanks for your answer :slight_smile :
deletedlc
  • 46 replies
  • February 22, 2023
Hi Alexiss,
Thanks for wanting to make something to make everyone’s life easier. I’m a bit confused with the screenshot:
  • there are five grey circles under the Plugin title bar. I’m assuming the Plugin title bar means the Plugin is contained within a window within Figma, and it could be dragged around with cursor. If that is the case, then the five grey circles, I assume, represents different plugins that the user could click on and switch between?
  • following the previous bullet point - if these circles allow the user to switch between different plugins within the same overlay window, how would you address the difference between each plugin’s pop-up’s layout? (e.g. one plugin might by default opens a 300x180 window on launch, yet another plugin might by default opens a 600x400 window.)
  • 4710 replies
  • February 22, 2023
You can make a catalogue of plugins but Figma doesn’t have any mechanisms for plugins to interact with each other. In particular you can’t in any way shape or form launch one plugin with the help of or inside of another one. You can’t even run two plugins at the same time manually. So this idea is only technically possible in the dreams. The only way would be to make a catalogue and the user has to open the native plugins menu and search for plugins manually if they find something they need in your catalogue.
Alexiss
  • 9 replies
  • February 22, 2023
No, the idea is not to create a new catalog but to facilitate the navigation between the plugins, so the bar at the top will represent the plugins that the user has selected (his favorites) and he can click on any gray circle to navigate to another plugin.
The window will automatically resize itself
Alexiss
  • 9 replies
  • February 22, 2023
Hi, thanks for your answer, I may not have been very clear.
The idea is that indeed the grey dots represent different plugins and when the user will click on one or the other grey dot he will be able to switch to another plugin, thus facilitating the navigation between the plugins.
The plugin window will be automatically resized according to the selected plugin.
  • 4710 replies
  • February 22, 2023
Your idea is not possible to implement in Figma with the current API.
Alexiss
  • 9 replies
  • February 22, 2023
I made a first POC and I succeeded it is quite possible I came here just to know if it would interest people?
  • 4710 replies
  • February 22, 2023
You might want to check with the Figma team first whether publishing this would violate any Figma rules or plugin devs intellectual property rights (not sure if scraping and running others’ code is ok). If so, sure, this could be useful to people.
Alexiss
  • 9 replies
  • February 22, 2023
Do you know how I can get this information?
Who should I contact?
  • 4710 replies
  • February 23, 2023
Regular Figma support would work
  • 4710 replies
  • February 23, 2023
I’d like to also note that as a plugin developer I don’t want my plugins to be a part of this. I want users to only use the native plugins system to run my plugins.
Alexiss
  • 9 replies
  • March 27, 2023
Hi just wanted to continue this thread to share the plugin : Plugins Navigator [BETA] | Figma Community
It’s still in beta but don’t hesitate if you have any feedback.
Enjoy!
