Importing a class(sample.ts) in code.ts throws error
  • December 5, 2022
  • 820 views
Anand_Kumar
Recently started to learn Figma Plugin where I could not figure not how to import a sample.ts file in code.ts
example: I had created a file called sample.ts which contains a function
export function testing() { return 'ABC'; }
Adding the following code in code.ts
import { testing } from './sample' console.log(testing())
I see following error in the console
Syntax error on line 80: Unexpected token import { testing } from './sample';
Best answer by Gleb
You need to compile the code to a single file instead of keeping them as separate modules.
  • 4709 replies
  • December 5, 2022
Anand_Kumar
@Gleb Thank for the response.
