I can't import files into my Drafts (Starter Plan)
  • September 10, 2024
  • 4 replies
  • 134 views
Varun_Verma
I understand that we are allowed unlimited files in our Drafts section, even if on a Starter Plan.
But ever since the changes to how Drafts work, I can no longer import files directly into my Drafts section which I could do before by following the usual ‘+ Create new’ file flow. I get an error message saying I’ve reached my Starter Plan file limit.
Has anyone noticed this? I had been regularly importing files to my Drafts to record professional work in my personal Figma account for portfolio updating.
Varun
Nellya
  • 662 replies
You probably tried to create new file in project, not the drafts. Can you provide a screenshot?
Varun_Verma
  • 6 replies
  • September 13, 2024
No I’m definitely in my Drafts section, hitting ‘+Create new’ button, see attached screenshot.
It seems now the import function is agnostic to the section you’re in, so just assumes you’re trying to import files into a project, hence the blocking message. This didn’t used to happen before. And it makes no sense from a user perspective because I can add a single Design file - and multiple times - while in my Drafts section with no issue, so there should be no restriction on importing any number of files instead.
Nellya
  • 662 replies
  • September 15, 2024
I just tried to import new file in drafts in a free team that reached the limits — you are right, i couldn’t do it either. That’s strange. Seems like a bug to me.
But i found solution — create new free team without any files, import new file there and then move it wherever you want.
Varun_Verma
  • 6 replies
  • September 20, 2024
Hey, good thinking! That worked for me too!
Thank you 😊
