For an product I’m working on, the design team has a system used by all designers. We hand-off designs both in english and arabic. So all components and pages need to support switching the initial english (left to right alignment) design to arabic design (right to left). Currently, I handle this in the following way: English font is [x] and arabic font is [y] → add the font names as typography variables to switch between Text direction, english [ltr] and arabic [rtl] → manually handle or use a plugin like RTL layout Components for english [ltr] and arabic [rtl] view → eg list, checkbox, header → add layout direction variants to change multiple elements direction to right for arabic The problem with all of this is that it’s a lengthy process which is not scalable. The ideal solution would be that when a language is identified and set as a property/variable/setting, then on each element/frame figma smartly set the right rtl expectation → text direction right aligned, set font and it’s si
As editor and maybe also as viewer I want to be able to see where specific components are used. So I’m basically talking about way to find instances of a component across files. There’s a plugin called “Instance Finder” but unfortunately it’s just working within one file not across. For huge design systems with multiple files and different designers working on it this is far from ideal. This idea is not new but since the other topics are closed I guess I need to open a new thread. See: Searching for component instance in a view-only file Ask the community I am a manager of the design system library in my org and I am trying to find instances of components in other designer files via the Org Libraries options, to see how components are being used. Clicking on a component takes me to the design file, but it doesn’t link to the frame where the component is used, which is what I would expect (even if it’s used in multiple instances, I would want to see at least one of them). So I have to m
My company is currently on Professional Plan. As more people (e.g. marketing, sales, customer service) are joining Figma, we are thinking of creating another team to manage this more effectively. I see that Professional comes with 1 team. What is the cost of adding an additional team? Can you transfer existing seats to the new team? If I am part of both teams, do I pay for two seats? Thanks
Hello, all, my name is Marina. I am a graphic designer lives in Greece. I have also background in web design. The last year decoded to transit to UX/UI Design. I have finished the Google course and started getting into deep learning of Figma. I have started with a web site for an African NGO that is called KIRC. I have watched plenty of videos and tried to practice in “auto layout” and figure out how I can create a responsive web page. I realised that there must be two ways : Either create frames for different devices or create frames and component with “auto layout”. Can you help me to clear this in my mind and follow a clear pat? Here is the link of my web page: Have a nice day. Marina
Hello. I have recieved notification on email that my student plan expires in 4 weeks, though it has been only 1 year since i’ve registered in figma and i also verified my edu plan this year. I have read that student plan is valid for 2 years, so why mine expires so soon?
Hi folks! We create a lot of presentations and usually design them on Figma, then export them as PDFs. Now, with the latest Figma Slides option, this opens up new ways of presenting and sharing presentations. There is one issue I’ve encountered and need help with. There’s an option where you can select all the frames you want to export – then go to the “Actions” field and type “copy…” to get the option to select “Copy to Figma Slides.” This opens all your selected frames perfectly on Figma Slides. However, sometimes the option to select “Copy to Figma Slides” in the “Actions” panel is not available. WHY? Here with “copy to Figma slides”: Here suddenly without “copy to Figma slides”: Can anyone tell me where the hidden Copy to Figma Slides button is? Thanks! 💐
As the title suggests, it would be terribly useful to be able to reset just the padding override for a specific component instead of having to hit reset all just to be able to set the padding to “inherited from master component” and remove any overrides.
I haven’t used Invision in a while. When I recently wanted to check out some old projects (~2019) for my portfolio, I realized that all my prototypes in the Studio App was gone. Customer support informed me that the app was fully deactiated and removed back in jan 2023. I have the .studio source files on a harddrive. Is there any was to convert/import these projects and open them in Figma (or Adobe XD/any other software)?? I would so so so appreciate any tips and help! It would really suck if all my projects are gone for good… Thank you!!
When I toggle an icon inside a styled (variant) button, its focus ring or outline remains visible even after it’s turned off. The only way to remove it is to activate a different icon, which clears the issue. However, when I toggle the same icon on again, the focus outline shows up and doesn’t disappear, as if it’s stuck.
Seems you can only add numbers or strings to text layers. It would be great if you could output a color value as text. It’d be really useful for setting up a style guide template that can be updated to different themes.
Hello. I am trying to develop my android application. Now I am creating design for this. I don’t know how to do prototype between text input and opening user’s account of this app.For example,If I want to log in my account in this app,I should insert text in such strings as login and password and after this my account opens. How to do this? How to setup a right prototype in this case before coding?
What are some effective strategies for improving SEO rankings for a website in a highly competitive niche without relying heavily on paid advertising?
Assignment Example Application (Critical Path)A furniture making company builds tables that consist of a drawer, four legs, and the top of the table. Building legs takes 11 hours, building the top takes 3 hours, and building the drawer takes 10 hours. After each part is built, eachpart is painted. The legs take 2 hours, top 1 hour, and the drawer 3 hours. The drawer is then attached to the tabletop (1 hour). After the top and drawer are attached, the four legs can be attached (1 hour).Find the critical Path.
Would be great to have basic formatting properties for tables. Cell color is not enough to create certain data visualizations. Stroke properties: color, weight, line type (dashed, solid) Merge cells: just a must Drop shadow: for table as a whole. At least in design mode Headers: ability to select hoe many rows to display as header Footers: same as headers Alternating colors Basic filtering or tagging Support in design files
Find answers, learn more.
