How to design a restore plugin that can export exactly how we write code?
Design is fun but restore it is not
especially when I have to do it again and again.
I have tried to build a such tool but finally failed.
I can do it if auto-layout is applied to the design but I think I can not force people use auto-layout. Then I find it is really hard for me to transform layout from Figma to the way I code.
In order to solve this, I try to transform absolute layout to flex layout (auto-layout in web)
The basic algorithm is
1: get all elements from Figma api
2: get all bounding box with x, y width, height
3: try to seperate the box into different lines ( if elements overlap then same line)
4: for every line, if elemets overlap, find the minimum elements that should use absolute position
5: apply other attributes based on Figma api doc
I have checked lots of similar plugin but none work fine
Does anyone have suggestions on this?
The oirgin topic is here
