How do I get a link to a file with a plugin?
  • May 25, 2023
  • 1255 views
Evan_Cheng
I’ve been tasked with developing a publicwidget that can retrieve the share link that one gets when they share a Figma file.
From the research I’ve done, it seems like this is impossible because the file_key is only available with the private plugin API, but I wanted to make a forum post in case there’s any little-known work-arounds I hadn’t considered.
The best work-around I could come up with is to use the RESTful API to GET FILES and match the file names against the file name from the plugin API for the file_key, but this would require loads of HTTP Requests (1 for each project) and require the user paste in their team link :c
Here are some of the sources I viewed in researching this problem:
  • 4873 replies
  • May 25, 2023
Everything you listed is the only available way to achieve what you want with REST and Plugin API. To date, nothing has changed.
