Hidden "base" components do not update after publish when parent component is detached?
  • November 3, 2022
  • 5 replies
  • 905 views
david.demet
So i have this Card component and it has a “.cardHeader” base component. I mostly use the “Card” component → detach instance → and then i can still edit properties on the “.cardHeader” but if i make changes to it, the hidden component does not update because the parent is not linked anymore. So it would be really usefull if it did update, or is there a workaround for this ? Now i just take a new instance from card but i have to reconfigure the whole card again
Saroj_Gurung1
I don’t know if there would be another input, so I am putting my two cents from my experience.
I think when you detach, you are detaching the link to the component “Card” that gets updated. Sure, the inner component is still an instance of the base which is why you get the options to edit the properties.
Only thing I can think of is if you make the allow the base component to get updated(publish) without the “.” at the start. Eventually making the base component another atom that gets updated as you publish.
david.demet
Yeah that is true, and if i would remove the “.” it will update, but i don’t want the sub components (in this case for example the card header) to be in my component library, that way your library gets cluttered fast with components you won’t use on its own.
Same problem here. We’re hiding our sub components with an “.” to avoid the library from getting cluttered. It would be great if detached parent components using those sub components would still update.
Any other way to accomplish this without publishing any sub component?
Bjorn_Witte
  • December 16, 2022
I seem to remember that it used to work. We could hide helper components with “.” and
nevertheless after a detach of the parent component the hidden helper components kept updating. Today we noticed the same problem and it breaks our whole library concept… Sometimes it’s necessary that other designers have to detach the master but wont detach the hidden helper components.
if someone has a tip please let me know otherwise please fix this @figma
  • January 15, 2023
