Help. Trying to stretch the frame only but other components are stretched with it
  • August 2, 2022
  • 9 replies
  • 11443 views
Lezhang
When I try to stretch the frame, other components are also stretched, as you can see in my screen shots. I only want to edit the frame. How can I do it?
  • 4873 replies
  • August 3, 2022
Set the correct constraints and resize the frames. Or:
Lezhang
  • August 3, 2022
I figured it out, thank you so much!
Jesuferanmi
This worked! Thank you.
  • February 28, 2023
This worked for me too! Thanks!
Thanks, it helped
Gary_Mcbilly
I want to resize the frame because I realized I have to add more items below. But I do not want anything I have already designed to move. However, when I try to add to increase the frame height then everything starts to move on the frame. So I stopped and I am trying to rebuild the whole frame. However I am sure that there is a solution for this. Kindly help!
221B
  • February 15, 2025
Thanks it works. Just hold ctrl and drag!
kilu
  • March 11, 2025
Thank you. It works!!!
kmart
  • April 22, 2025
Do you want to resize the frame ignoring the constraints? Hold Cmd/Ctrl and drag the border of the frame.
two years after: this helped me!! Thanks
