I want to adjust the middle. So if I push the middle to the right, the red square get larger horizontally and red smaller and vice versa.
I tried selecting both and moving the middle but it doesn’t work.
Thanks.
Thanks.
You can put them in an autolayout
And set one of the green rectangle width to “Fill”
When you will resize the red rectangle, the green will take the remaining space
Hi Stephane, thanks. I tried it but I would like both extremes of both rectangles to keep in place and move just the middle between them. Would you mind taking a look here? Feel free to make any change. https://www.figma.com/file/HEPqxBBsvO0YJrVQSrxN2t/Untitled?type=design&node-id=0%3A1&t=RgGdIXIDcKXU8XJq-1
Hi Stephane, thanks for the response. I tried it but it’s not the result I’m looking for. I would like both extremes of both rectangles to keep in place and move just the middle between them.
Would you mind taking a look here? Feel free to make any changes.
I tried to make a working example here https://www.figma.com/file/RzGFzfYHTxkWai1MvQykOO/Untitled-(Copy)?type=design&node-id=1%3A2&t=QPl6kkm28CKhqr2o-1
