I created a component library for my company. In this library, when i click on components or copy-paste this compınents to another page, font changes and i need to change is manually after. With font replacer plugin, i solved this issue however this is a temporary solution. By the way, changed fonts are not a font in my computer.
@Atakan, @Fsevgili, try to correct the text with the command “Recompute text layout in selection”. Alternatively, you can use the “Regenerate all instances (slow)” command. To do this, you need to open the “Quick action” (search engine in the file) and start typing these commands.
Same problem here. It’s a real concern because we have hundreds of pages, we are maybe 10 or 12 to work on it and it seems that some people just need to touch an object to change the font to something else…
