Figma should remember the last library searched when using Resources/Components
Currently each time a user searches components using the Resources tab, the search category is always “Recents”. It would be useful if Figma remembered which library the user had searched because it is likely they will want to continue searching the same library.
Every time I use this function I have to select the library. I never search “Recents” because I need to be sure the component I’m seeing is from the correct library and the only way to find out is to use the component. Figma should indicate which component library the component belongs to when showing search results.
