Hello
I can not seem to figure out how to expose the properties of a subcomponent within any given component.
Thanks in advance.
-a
- Select the main component or component set.
- In the right panel, next to “Properties” click “+” and select “Nested instances”.
- Check the instances whose properties you want to show.
- Create an instance of the component, and check its exposed properties in the properties panel.
Thank you - I did finally find it, did not know to look in the + next to properties.
