"Expose nested properties" not working on instance-swapped components
  • September 30, 2024
  • 33 views
Julia57
I have a modal drawer component, where the body is just one big slot. So the designer would make their drawer content into a component, and swap that into the slot. The problem is that the drawer contents have states and variants, but none of these are surfaced at the top level, even when I try to expose them.
Chelsea_Studenski
I’m having this same issue. Likely going to have to redo a set of work as a result to break out some cards into seperate components since they are almost unusable in design mockups without the nested properties accessible.
