Expose/hide nested instances -> at component property level
Zoltan_Szalay
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure.
Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component.
What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
Bjorn_Witte
  • 5 replies
  • September 22, 2022
+1 Same Problems! We need the possibility to hide props we don’t want to export for our users.
Lea_Delazer1
+1 from me too, very much needed and it would be such a game changer in our DS. Hope this will be possible at some point!
Andreas_Falkenberg
+1, is really needed!
0xtutti
  • 12 replies
  • October 1, 2022
+1, this is really needed.
hummh
  • 11 replies
  • October 12, 2022
Same here. The feature is a very good start, but to make it really usable it should be possible to choose which properties from nested components should be exposed / or not in a specific context. Currently it’s everything or nothing. But everything might be too much.
_Sergei_Zhukov
I agree with Harald. It is important to choose which properties from nested components should be exposed / or not in a specific context 🚀
Yaroslav_Zonov1
Same. I think it is necessary to implement this improvement, in Sketch this option worked exactly like this
andy4
  • November 1, 2022
100% this. I had this exact same thought yesterday. I’m also glad to hear that I wasn’t misremembering that this is an option in Sketch.
Harun_Alikadic1
+1 currently I am not able to use this feature in many cases because it surfaces too many options and only few are needed on the component level.
Bertrand_Fouillet1
Managing nested instance in a complex table component makes the table component itself unusable. You approach is simple and fix this issue +1
Greg_Smith
  • 11 replies
  • November 22, 2022
Would love the option to hide component props from consumers. For instance:
Component A
  • Nested component B
  • Nested component C
Component A is made up of two nested components, B and C. Components B and C have properties that are adjusted to provide variants of Component A. They’re really just for my use.
But if a designer “clicks in” to Component B, for instance, they can see its props, in the right sidebar (which I’ve used primarily to make those Component A variants). I don’t want them to touch the props for that nested Component B. I’d like to hide them.
I heard rumors that this might be an upcoming feature. Is this true? 🤔
Sanket_Chaudhari
+1 - need capabilities to expose selected properties from within our nested instances. Cannot use this feature without it.
Josh_Loya
  • 5 replies
  • November 27, 2022
I’m running into this limitation, too. Being able to expose properties from nested instances is the right direction, but I need to be able to selectively expose properties, rather than an all-or-nothing toggle.
Andreas_Haimerl
Would also be highly interested in this. Would make things much easier for the consumers of our enterprise Design System.
Tim_Hose
  • January 4, 2023
Replying to keep this alive. Our group would love this feature, as something like tabs or lists with nested components becomes such a massive list that they’re not usable.
sweetdrumster
Agree. It is vital to be able to mark props as private/public or simply specify which of nested components’ props should propagate to their parent.
MarcoD
  • January 24, 2023
+1, we really need this.
Adam_Przewoski
Keeping the thread alive, +1!
Namson
  • 9 replies
  • February 3, 2023
We need this as well!
Erin_HG
  • February 8, 2023
+1 This would make exposing nested instances much more useful for my team as well.
ckeramidas
+1, need this
+1 Please 🙏
Sarah_Proulx1
+1 exactly my problem, thank you :)!
Amanda_Bohlin1
+1 This would be so helpful!
tlapetite
  • February 23, 2023
+1, really needed for more complex design systems!
