Launched: Export Compressed PDFs
  • May 13, 2021
  • 47 replies
  • 23617 views
Leon
    When I export out PDFs and attach them to emails for review for stakeholders who either are not in Figma or just prefer to review and leave notes via PDF mockups, I always have to find a PDF compression solution that can shrink down the sizes. In addition to PDF compression, sometimes merging multiple files into a single document is something that I wish Figma gave some options for when exporting.
    PDFs exported when they contain some kind of image seem to be quite large, maybe because the whole image is intact and it isn’t cropped down. Or just the quality is retained as close as possible to the Figma quality.
    I’m not aware of any community plugin that solves this. Are there any out there?
  • May 14, 2021
This is available via the TinyImage or Pitchdeck Studio plugins.
Jaclyn_Tan
I would like to see a better implementation of Figma’s export to PDF feature. I know PDF is an Adobe format, but there is something about the way Figma exports pdfs that blows out file sizes excessively.
Designers commonly mock up print files such as resumes and brand guides in Figma, but sometimes people may want to export these files out to pdf to send to people by email. If you have many assets or images, the pdf Figma exports is excessively large.
For example, I exported a two page style guide the other day and it came out to 24MB!!! Even if I downsized the images, the images which were in a clip mask was saved out as a raster image, which is not ideal because PDF should ideally contain vectors. And even then it came out to 5mb.
I had to redesign the entire thing in InDesign where I could then save it out as an interactive PDF. The whole thing came out to 500kb…
PDF is an important file format (right now) and designers need it for a lot of use cases. But I do think the export to pdf feature could be drastically improved on Figma. I know it could be a monumental task given that the format is Adobe and Figma is primarily for digital design. But the PDF format is important too, and what is the point of having an export to pdf feature if the end result is completely unoptimised and unusable?
Mark_Alford
Same issue - basically produced a 50mb pdf.
Analysing the pdf two key areas that need addressing
  • image optimisation - ideally be able to select dpi - 150/225 etc.
  • fonts - these are not embedded, all text is converted to vectors that obviously ends up being significantly larger than it should be - by a factor of at least 10x.
If those key issues were solved believe the size of the pdfs would be very similar to pdfs produced through adobe software such as indesign etc.
Edward_Flora
This is why I use an online tool to compress the PDF file size…
Mark_Alford
@Edward_Flora Online tools only do so much, key issues with the large file size are due to
  • text converted to vectors rather than simply embedding the font - online optimisation tools or plugins such as TinyImage won’t fix this
  • Images should be optimised to a required dpi level (ie. 225, 300 etc)
Hoby-Van-Hoose
TinyImage is currently commercial, starting at $15 per month and going up from there. That might not be a viable option for a lot of people now.
  • August 4, 2021
It always was a paid plugin.
Jake2
  • September 29, 2021
Same issue. 3 page basic PDF was 72MB!!
Seferidis
  • October 15, 2021
Hello.
We are creating lots of printable documents in Figma and when I export them as PDFs their file size is huge compared to an SVG export.
The problem can be reproduced here:
Figma – 15 Oct 21
exporting this relatively simple frame weights at about 25 MBs !!!.
In our production more detailed frames weight 95mbs.
An SVG export on comparison weights ~2mb.
It would be really cool if we could have some sort of PDF options to include smallest possible filesize or allow text to outlines etc.
Rakesh_Arvapalli
I believe this is a known issue. I usually export the PDF compress it using mac’s own preview app. It worked for me in the past
Andre8
  • October 21, 2021
Acrobat online will compress your PDF for free.
Its also an Adobe site, so somewhat more trustworthy than some random site out there that does something similar. 🤷🏽‍♂️
(Can’t include a link, but…)
Search for: acrobat/online/compress-pdf.html
Hoby-Van-Hoose
  • October 27, 2021
I’ve used Compress PDF online. Same PDF quality less file size for a while and will continue to use it for my infrequent PDF sharing needs. I thought that the TinyImage plugin would be a better solution but after the trial period, it doesn’t make financial sense for me to keep using it (for pdfs or even the other formats it exports smaller).
It would be best if Figma just had this built in, for every export format including PDF.
Why would anyone intentionally export files that are several times larger than what’s possible to output?
Ricardo_Sawir
Any progress on this?
I agree - there should be settings within Figma to manage the size of the PDF export. Options mentioned in this thread are not great. This is the one downside I am seeing for Figma vs Sketch. I never had this issue in Sketch, even with massive files. Sending large PDF files to clients for review is not great since many email clients have max for file sizes.
Dima_Novosad
  • February 11, 2022
Hey guys, so I am creating PDF decks for briefs and if I export PDF via File > Export Frames as PDF then the 3 page deck with 5 photos is roughly 33MB. Sometimes these pdfs go like 150-300mbs. Could there be a setting like there is for jpg/png to control the level of compression/optimization. Adobe Acrobat has a tool and I just wonder can this be ported over? Maybe there is a plugin I am missing out on?
Kyle_Dumovic
TinyImage-Compressor is a great tool but it’s prohibitively expensive for me ($12 per month!). I thought it was free but they charge you after 15 exports. Wish Figma had a baked-in solution to this mess. 🙏
james_work
Agreed — Figma is terrible at PDF exporting — and that is a big problem when generating decks for business and exec leadership.
There are hardly any features baked in — it’s not even possible to export only selected Frames, or export based on pasteboard order (top to bottom, left to right) — and on top of that the exports are MASSIVE — even when therer is only a few bitmaps (screenshots) with the rest as vectors. If you work in a large org, you essentially need to export and share decks via PDF, and they have to fit into an email. This is a massive problem I’ve encountered. A 33 page deck is 144mb exported from Figma, and worst of all the export is done in a weird and non-optimal way that even Acrobat can’t fix. A similar deck exported from Sketch would optimize down to about 4mb.
This kind of thing is so foundational to the design process… and not every org is setup for click though prototypes and live comments. Some things need to be documented into PDFs as part of the approval process.
Chris_C
  • April 4, 2022
This PDF export size issue is %$1! torture
Chelsea_Barbano
I really would love some way to compress PDFs in figma like others have said as well. Not only would it help with stakeholders reviewing, but also for any PDFs that have to be uploaded into a submission platform like Veeva. We almost missed a submission because even with using some compression software (tried adobe’s PDF compressor and small PDF) it wouldn’t upload into the submission platform. When using sketch for the same exact project we never almost missed a submission due to this because the PDF came out small enough and could compress even further without it looking bad. We ended up having to submit something that was pretty pixelated so that it would upload.
Eva_Huse_Pedersen
Ohh nooo, I built up my school project report with Figma and it’s too large. I am afraid I need to do it with InDesign and build up again 😦
I tried everything but there is no way to compress it below the requirement, 200 MB.
This is horrible.
Figma, please do something with this
LazyDeveloper
You can try PowerPoint, just go to design and customize the page, then arrange the exported picture accordingly just tried it.
Hope it works for you
Weronika_S
  • August 30, 2022
I downloaded “TinyImage Compressor” plugin on Figma and it works!!! finally… 😫 🙌
Dennis_N
  • September 8, 2022
Figma pdf export = 200mb
3rd party tool = 2mb
Yikes.
I don’t want to be depended on 3rd party apps.
Norah_Medlin
The Adobe online Compress tool worked great!
Hanefi
  • September 26, 2022
Since Adobe has Figma, maybe now is a good time to work on a better implementation of PDF export feature? Illustrator’s “smallest file size” option is a gem.
