Some codegen plugins provide the ability to export code snippets. Just click on the “Inspect settings” icon next to the plugin name and select the item you need.
I am unsure where this setting is.
This is what i see in my inspect panel for a codegen plugin
Thanks for the response. However this is not an exiting code generation plugin that i am trying to download.
I am creating a new plugin and want an option to download the generated output.
Can you please guide me for the same.
In this case, you need to study the following docs:
figma.com
https://www.figma.com/plugin-docs/api/CodegenPreferencesEvent/
In short: add codegenPreferences
to the manifest, listen to the preferenceschange
event, pass the code to the UI and call the download function.
Thank you, i have already checked some of the docs and will explore others too.
Also you mentioned call the download function, are you referring to some native method for this ? Any example that i can leverage ?
stackoverflow.com
You can also Google it yourself.
Ah nice, a javascript function is even better. Initially i thought if there is any native support from Figma for downloads. Thanks @tank666
Hi @nirvana7 and @tank666, I am working on a similar problem where I am trying to access the native HTML code generated by in the Figma Inspect panel shown below via the API →
Is there a way for my plugin to access this natively generated code via the API?
In this screenshot I can see that the HTML code was generated by a third party plugin. In this case, I suggest you contact its creator.
