Distribute spacing doesn't work on variants
This morning I have an issue with distribute spacing for both horizontal and vertical, but only in variants, so when I want to distribute variants under one component this option doesn’t work.
On the frame or canvas with other objects, it works normally.
ksn
  • 1827 replies
  • March 8, 2024
Hey @Mike_K1 – I think it would be best to have someone on our side to look at your set up. I’m not too confident on providing a solid answer on this one.
I’m leaving this open to see if someone from the community will jump in, but you can file a ticket here to get someone to help in your exact instance here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
yuukun
  • 4 replies
  • March 11, 2024
Hey there, I think I found something that might be broken?
I’m not sure how it used to work before the update, but at least as of right now I also cant distribute objects if they’re variants of a component.
2024-03-11-18.12.42
Sorry if this is the intended behavior, although I don’t really think it should be…
tzuyu.huang
Hello, @ksn I’m experience the same issue.
+1 on the same issue
Arthur_Dao
  • 2545 replies
  • March 12, 2024
Thank you all for the feedback! I shared this issue with our internal team. We cannot guarantee if it’s prioritized but we will let you know if there is anything I can share with you.
Thanks for your patience!
Peter_Nagy
Same here, since the new “Multi-edit” feature exists.
Atrialub
  • March 12, 2024
+1 Same issue, I know it had worked before because I could organize components variants using “distribute horizontal/vertical spacing”
  • 2545 replies
  • March 13, 2024
Hi all,
Our engineering team confirmed it was a regression and fixed it. Could you reload the tab and try again please?
I could see that it’s fixed but please feel free to let us know if it isn’t.
Thanks again!
