Is it possible to save a grid style that will appear in all my projects?
Similar to what can be done with color style?
I have a free version
Hey,
Yes here.
But to make it visible in all your projects you need to have a library that contains the styles. This library needs to be connected to the file that you wanna use the predefined styles in. (You can either click the button Browse librariers… or Left panel → top bar → click Assets-> click the book on the right … you can also publish a library from here)
Have a great day
Yes thank you
This is exactly what I was trying to do
How do I publish a library?
To appear in all my projects?
To set up a library and share it is dead simple! from a file you go into Assets on the left hand menu, press the libraries button
then you will see the libraries in the file with a “Publish” button and voila!
If you want it to be as standard for all new projects you can either import it to a new project or the team manager can set it up as a “standard” library in the team settings and it will be active from the start in each new file you create in the teams library.
Thank you
My problem is I do not know how to do it
Blockquote
Blockquote
In the top right of the figma mainpage (where you see all your files) you can go to your profile picture on the top right to access the settings, in the settings you should be able to scroll down and find this point
Here you can activate or deactivate certain libraries.
If you have another payed plan and you are the admin you have other options
like these (organization plan)
Thank you very much for your help
I found a desing system file
It probably comes as a default in figma
Inside I applied the grid styles
And now they appear to me in all the files
(The file is marked with a black arrow)
