I have created a component which will change to another variant of it when I click a button but when prototyping the change is not happening. What could be the issue?
The edit button is not changing to save button
I am having the same issue. Components that were previously transitioning to states (hover ie) are now not working correctly.
What has changed since? We upgraded to Org pricing tier.
Did it work properly before? If so, please submit a bug report to support.
Try removing the button component’s text property. Or create and use a new component that meets the requirements of this task.
I have tried the following with no success.
• create a new component
• Reload tabs / all tabs
• Restart Figma
• Restart computer.
Could you share a link to an example file?
Got response from Figma that this is a know issue where text properties are not swapped as expected when a component is setup with both a on-click and a hover interaction. (Nested as well).
Solution: You can remove hover effect from components interaction section, nested as well.
