Component Library is updating to an older version
  • November 15, 2024
  • 32 views
Philip_Hodges
Made changes in the component library. No matter what I do the file using the components will show the blue dot to update when it should, but selecting update is reverting to an older version. Even if I copy components directly from the library and paste them in, my local file will show they need updating and when I do so they revert to an old version. Causing so many problems.
Gayani_S
  • 2189 replies
  • November 15, 2024
Hey @Philip_Hodges, thank you for reaching out! I understand how frustrating it can be when components keep reverting to older versions despite your updates.
  1. You can use a different version history which might resolve the issue for you: View a file’s version history
    Can you please take a look and see if you can restore an older version which does not have the older component state?
  2. Please double-check that all related components and styles in your library are fully updated.
I came across a similar case where the issue was caused by some styles still being linked to a different system. Even though the user had updated their buttons, there were “ghost links” that caused unexpected behavior. Deleting those residual links and ensuring everything pointed to the correct system resolved the problem.
Let me know if any of these steps help or if you’re still experiencing the issue. I’m happy to help further!
