Color picker/eyedropper should apply color style
Sam_Gray
When using the color picker, if the object you’re picking from has a color style applied, the color picker doesn’t apply that style to the selected object — it just applies the hex value (or whatever color model you have set) of the pixel you click. This can lead to messy colors not adhering to your style guide.
Instead, the color picker should apply the color style of the clicked object if it has one. (You could click the stroke to apply the stroke’s color style, or the fill to apply the fill’s color style.)
If you do want to be able to pick the pixel color instead of the style, there could be an additional modifier key to hold while clicking.
With the current functionality, if you want to apply the same color style to another object, you first have to click the already-styled object to see what style is applied (assuming you may have multiple similar shades and can’t eyeball it), then click the object you want to style, and then find that color style in the list and apply it. The proposed workflow would be: click the object you want to style, press Ctrl-C, click the already-styled object.
Illustrator works this way — “global” colors (equivalent to color styles) are applied when an object styled with one is clicked with the eyedropper tool.
Heather2
  • August 6, 2021
I have an object selected, and I want to change its colour to match another object with a fill from the Colour Library. When I use the colour picker, it captures the hex value of the other object. Later, when I edit that colour in the Colour Library, I want all objects using that colour style to update to the new colour. However, objects for which I have used the colour picker to fill are left out of this global style change, and I have to go back and update their fills to the Colour Library colours. If the colour picker picked up on the fact that the object’s fill is a colour in the Colour Library, I could avoid this extra step, and all my objects of the same colour would be linked through the Colour Library.
Does this bug anyone else?
Does anyone have a use-case where they don’t want the colour picker to set the selected object’s colour as the Colour Library colour, and do in fact just want the raw hex?
Anyone know of any plugins that do this?
Christian_Leon_Christensen
Can we bump this?
Andy_Merskin1
Agreed, I am really missing Illustrator’s fine-grained color picker tool where I can Alt/Opt + Click to apply the currently selected color to objects under my cursor, by path.
It made applying colors to certain pieces of complex icons and designs a breeze instead of having to go select everything I want first, then apply a single color. Losing a selection is easier (and more frustrating) than having the ability to fly around and apply colors like this.
AJ_Huxtable_Lee
It would be a really cool enhancement if the eyedropper tool ‘i’ could also copy text styles (like it does in InDesign). Being able to copy properties is fine, but having to manually select each text layer and copy the properties, to then manually select each text layer and paste those properties is a bit of a pain.
It would be ace if you could eyedropper the text style you want and ‘dropper’ the style onto the text you’d like to update. InDesign does this really well.
If a color style has been applied to an object it would be helpful if the selection made by the eyedropper tool was that color style, rather than the hex value.
Gary_Pikovsky
Guys - switching over from Illlustrator and loving Figma. But it looks like you can’t use the eyedropper tool to copy/paste text styles. This would be a massive timesaver!
I know there’s copy/paste properties. But it doesn’t copy all properties and is a significantly more lengthy shortcut that eyedropper and thus becomes painfully slow.
Please add this feature soon!
  • 4873 replies
  • November 4, 2021
A post was merged into an existing topic: Use eyedropper tool to copy and paste text styles
Marianne1
  • 4 replies
  • November 13, 2021
it’s been a few months - hope this can get implemented! This would really speed up my workflow too
johannes.ecker
One small issue I have while working in Figma is that I sometimes want to assign a certain style to my current selection. The only way to do this now is to move with the mouse to the right panel and search/select the style from the menus.
Often times, another element with the needed styling is already somewhere on the canvas, and I would like to be able to copy that style from this element; however the eyedropper tool only picks up hardcoded color values.
My improvement idea is that with an additional modifier key that you can press after entering the eyedropper selection mode, you could enable a “pick up style” mode instead.
This way I could assign styles to objects on the canvas much quicker.
See attached schema for a visual explanation.
In case multiple styles are assigned to the “source” (fill + stroke + effects) I guess the easiest would be to copy all of them over to the target object.
I guess it could also work with text layers, where this mode would pick up both the typography style of the layer and the color.
What do you think? Any big downsides I am missing?
Filipe_Ferreira
Make a modifier of some sorts that would allow the eyedropper to paste a color style. Ex.: pressing Ctrl with eyedropper selected. Perhaps it could work for Text Styles too with a different modifier.
This would work only for colors, which solves the problem of the only solution I currently know of how to deal with this - copy/pasting properties.
If anybody knows a workaround to this, feel free to share. Thanks
Adnan_Hassan
I agree with this, it will be a massive timesaver
Alex_Lama_Noujaim
Just bumping this as I use color picker very often especially when trying to prototype quickly, but I end up with a mess of hex codes that I then have to go back and apply correct color styles to. Picking up color styles would be amazing.
Dominic
  • 42 replies
  • October 11, 2022
Bump x2 Really need this! Please and ty
Ryan_Lockhart
Bump! I would really love this feature.
taps mic Is this thing on?
Jocelyn3
  • 4 replies
  • July 11, 2023
Would be really nice if the color picker /eyedropper could pick up color styles / variables (maybe with a modifier key pressed) instead of just the plain HEX code of a color.
This way, users wouldn’t need to always browse the color styles menu, but could pick up styles quickly from other objects.
This would also be quicker and easier then to copy styles via Option+CMD+C and paste via Option+CMD+V.
EDIT
Idea also exists here: Color picker/eyedropper should apply color style
Rolf_Wilkinson
No modifier needed. Eyedropper should get the color style. What am I missing here? I can’t imagine this would be a problem?
Makayla_Lovrak
I know this has been mentioned before but not for a bit. Instead of only being able to collect the HEX value when eyedropping a color, could you eyedrop the style connected to the item? This would change my life 🙏🏽
James_Garnham
  • 14 replies
  • February 22, 2024
Hi Figma, Any thoughts on this feature? (Perhaps adding the press of ‘alt’ when eye-dropping would pick the style and not the hex?)
  • 4943 replies
  • February 23, 2024
Hey All, thanks for the feedback!
We’ve merged a couple of similar, existing topics here together, so we can track overall interest from the community more accurately. We’ll pass this onto the team for future consideration.
Pedro_Gelli_Pereira_Tinoco_Alv
Hi, i would like to share a simple idea about picking color with the color picker.
I would like to pick the color style aplyed to the object.
Thats it 😃
Thanks!
Ryan_Brown1
  • 8 replies
  • September 2, 2024
Co-sign on this. Should be able to eyedrop either style or pixel color. Maybe you hold shift while you click the eyedropper on your target style
Jesper1
  • September 25, 2024
Came to the forum to suggest this - voting on this! 🙂
Could be eye dropping style by pressing shift or something while clicking.
Matthijs_Rouw
  • 9 replies
  • October 29, 2024
Having issues picking colors quickly as well.
We go through the hassle of creating design systems with (color) variables and tokens and once applied to an existing shape and picked after drawing a new shape, it picks the colour, not the token.
Each time you create a new shape to which you want to apply one of the existing colors in your page, makes you pull up the variables options instead - ugh
deb2
  • November 4, 2024
This would be a huge efficiency win. Its not just about being consistent when swapping out one color for another. I’m over here repeating the same library search 3 or 4 times when I want to consolidate multiple colors and turn them all into the same style. (why do I have so many colors? cuz random rogue hex codes keep proliferating when sampling!)
I thought I just hadn’t learned some cool shortcut, went searching, and now I find a several-year old thread 😦 If print design tools have attribute-based style sampling, a web tool should surely have this.
Jamie_Schmid
I kind of can’t believe this hasn’t been implemented, for font settings especially, and that this thread is 4 years old. This issue comes up for me OVER AND OVER. You can’t assume that everyone is going to have a perfectly formed style/tokenization in place.
