Can I navigate to a new page using an interactive component state?
  • March 18, 2021
  • 4 replies
  • 11118 views
sekeidesign
I have an interactive component that has a base state and a hover state.
I would like to be able to click on the hover state in my prototype, in order to navigate to another arbitrary page.
Is this possible? I can change the state of the component (to hover) in my prototype and connect it to another page, but when I switch it back to base, and then try out my prototype, that doesn’t actually work.
Best answer by Shane
Create your component with internal states, eg:
default --while hovering–> hover --while pressed–> pressed
Then just put it on a frame/screen, and add an on click interaction that goes to your desired frame (there’s no need to apply the onclick to the hover state, just the default will work).
Shane
  • 74 replies
  • March 18, 2021
kdeebee
  • March 27, 2021
I tried this and for some reason, the on click event stops working once I have hover at a lower level in the component. I tried it with hover and mouse enter / leave. Screenshot 2021-03-27 at 18.49.34 This is how it looks on the Prototype tab. When I remove the hover or mouse enter interactions, the on click works. It’s like the underlying hover interaction prevents or takes precedence over the on click. Any idea what I might be doing wrong? Thanks.
Shane
  • 74 replies
  • March 27, 2021
Try using “while hovering” rather than the mouse enter interaction? I’m away from my computer at the moment and can’t test it, but that’s the setup I usually use. Other thing might be to change the instance of the component to the mouse enter state in the design, and apply the on click event there. Shouldn’t make a difference, but this is a beta so you never know 🙂
kdeebee
  • March 28, 2021
Thanks Shane. That’s helpful. I changed it back to ‘while hovering’ and I noticed that there was an additional “change to” event that was triggered by an “on click” by mistake. So I cleaned that up and it works now. Tx!
