Bug Report: Variables don't scale correctly in instances. Instance does not match component
  • November 19, 2023
  • 505 views
thor3
Scaling breaks in component instances if a variable was used for the initial sizing. The instance does not match its source component.
Here is an example of the problem.
Figma
mo_hamwi
  • 49 replies
  • November 20, 2023
How are you scaling things, you should use the scaling tool
thor3
  • 8 replies
  • November 20, 2023
Regardless of what tool is used, there should never be a visual difference between a component and a fresh instance of that component. But yes, to answer your question, I used the scaling tool
Celine_
  • 3603 replies
  • November 21, 2023
Hey @thor3 ,
Thanks for reaching out to the community! This looks odd. I try to replicate on my end, and it works . (please see below the screen recording)
Can you please share a quick video recording the different steps when you did to shrink it to see what’s happened on your end?
