Auto layout instances don't hug content like in main component or detach instance
  • April 6, 2023
  • 1112 views
gimaf
  • 9 replies
I don’t know why, but auto layout won’t work on instances, only on the main component or on the detach instance. Is it a known bug? is there a workaround, beside detatching the instance?
Best answer by Pavel_Kiselev
Your spacer has fixed dimensions. If you want dynamic size inside your instances than you need to make spacer hug contents by default. I place a simple rect with dimensions I need inside hug contents layout so the final size isn’t set on the component level, but it’s defined by internal layers.
Pavel_Kiselev
  • 438 replies
  • April 6, 2023
