Allow boolean properties to be set to a variable
  • September 15, 2023
  • 428 views
Is there currently a way to set a component boolean property = a variable? Having this feature would allow creating a set variable interaction that toggles the boolean variable.
Alternatively, add an interaction action that is “Set Property Value”, where you can select a property and select a value from that property to change with the interaction.
It would also be useful if using an interaction you could set a variable = value of another variable.
