Adjust properties for instance swap value added in preferred values
  • May 3, 2023
  • 242 views
When I select an instance swap and select the preferred value, I would ideally want to set the default properties for that instance.
In my case, I want the user to swap a radio with label disabled with a checkbox, but when they swap the checkbox, it comes with the label enabled (as that is the default component).
I know the user can just change it but that is an extra step if i am setting up a card component so they can just use settings on the card, not drill down to the checkbox and turn label off.
  • August 1, 2023
