Additional Boolean Variables - Seperate visibility of fills/strokes/effects
  • September 29, 2023
  • 4 replies
  • 1467 views
Shawn_Willings
It would be great to be able to seperate the visibility objects beyond just the layer. To be able to associate a boolean variable to the visibility of;
  • Layer
  • Fill
  • Stroke
  • Effects
Would make it more effective when putting together a design system. This means that you could effectively determine that all buttons have outlines, or drop shadows or both right across the whole design.
See examples below.
Thoughts?
Aleks
  • 5 replies
  • May 6, 2024
Good idea.
Pavel_Kiselev
You can do it right away with layers though
Nik3
  • June 13, 2024
Yeah but it’s redundant. It would be way less data, if i give e.g. the button frame a specific border, filling ,radius (and the visibility of the border for example) all connected to variables. so that i only have to configure the stuff on the button frame not sublayers 🙂
Pavel_Kiselev
All true, indeed. However if you need things done today layers to the rescue. Another thought is that you make button once and move on, not a big deal. If you want to optimize the process you can separate visual layer into reusable style components
The concept explained here → Making of true multi-brand design system | by Pavel Kiselev | UX Collective, check under “Component styles” section
And if you want to see some live examples I have community file for you → https://www.figma.com/community/file/1372632073691205444/source-ds-forms
