Catherine_Desrochers
Sep 27, 2023 5:40 PM UTC
There should be an option to prevent interaction overlap between layers above and behind
The gif below should be self-explanatory about the issue
Enregistrement d’écran, le 2023-09-27 à 13.33.04.2023-09-27 13_35_47
Valtrip
Oct 20, 2023 7:21 AM UTC
I’m facing the exact same issue right now and can’t find a solution to it.
Must-have!
Bauke_Schildt
Oct 20, 2023 9:58 AM UTC
In your example, you could use the “open overlay” interaction.
(Sorry for the crude mockup)
Screenshot 2023-10-20 at 10.55.13
Mine opens On Click, but you can also have it open after a delay of 1ms on the frame.
The overlay option prevents any interaction with the original frame.
Oct 20, 2023 1:21 PM UTC
Indeed, it is a great solution for some use cases. But it remain an unwanted behaviour. I have multiple cases that comes in my mind to illustrate it ; for my screen capture, clicking on the three dots also open a menu that interact with the layers below.
I wonder if an overlay for absolutely everything is a great idea, especially since overlay positioning can be a little of a mess. I see these dropdown menus as variants than a link to an overlay.
Adding a simple checkbox to specify that we don’t want below interaction to interfere with a layer would be a good idea.
Bauke_Schildt
Oct 20, 2023 3:18 PM UTC
Oh, agreed, it’s an issue I’ve come across as well. There’s a bug in Presentation/Prototype mode where, if you follow someone going through the prototype and they open an overlay, sometimes you won’t see them opening the overlay. So we sometimes build our prototypes without Overlays to avoid that issue.
Oct 20, 2023 4:56 PM UTC
Regarding this issue, @Bauke_Schildt , submitting a bug to Figma may be not that intuitive, but once you are in the loop with them, they are quite proactive!n 🙂
Bauke_Schildt
Oct 20, 2023 5:07 PM UTC
You’re right, I should submit that as a bug. 🙂
robwrch
Oct 30, 2024 1:55 PM UTC
I have the exact same issue
Erik_van_der_Neut
Apr 21, 2025 1:20 AM UTC
This bug is seriously SO ANNOYING! Pulling my hair out on this one. How to work around this now in a complicated prototype. Just infuriating that this does not work properly.
Xavier_Godbout
Dec 8, 2025 8:02 PM UTC
2 years in and nothing has changed….
Hatim Dossaji
Dec 9, 2025 6:50 PM UTC
We need a “on mouse enter” disable interactions below. So on any dropdown, layers below would not interact all the while the drop down itself has all the required interactions (hover, click, etc)
