Phil_Larsen
Nov 10, 2021 10:09 PM UTC
Scroll to point in component
I regularly create components that allow for easy manipulation of prototypes at scale. I can’t, however, use the “Scroll” to prototyping feature on interior elements of a component. I need to break the component which then removes the benefits of having it as a component in the first place.
Could we get it so scrolling to an interior element of a component is an option?
Shane_Cullen
Apr 4, 2023 12:56 AM UTC
I have 5 buttons that when clicked they scroll down to a section lower on the page. When I prototype it the scroll-to works, when I create a component out of the frame and view the prototype, the scroll-to works in the component.
The issue is when I copy and paste this component as an instance on another page or file. Not only does the scroll-to interaction disappear from the instance but you cannot use the scroll-to interaction within an instance. Seems like a bug, I have seen a few other reports in the community and nobody has solved it or offered a solution. Very frustrating that it works perfectly in the component but does not work nor allow new scroll-to interactions for the instance.
Dennis_N
Power Member
Apr 5, 2023 11:25 AM UTC
Yes, there are uncountable posts and feature requests about this issue:
https://forum.figma.com/t/support-scroll-to-within-a-main-component-instances-2022/29045
https://forum.figma.com/t/scroll-to-prototype-is-not-working-in-components/32678
https://forum.figma.com/t/scrollto-inside-component-doesnt-work-for-the-instance/34254
@dvaliao maybe it would make sense to reopen and merge them or something. I saw you did that with other posts aswell.
Apr 5, 2023 3:52 PM UTC
Thanks for looping me in, @Dennis_N!
We’ve re-opened and merged all relevant topics regarding this feature. We’ll pass this along to the team to review.
Anne13
Dec 20, 2023 1:09 PM UTC
I also need this! I have a steps component where you open & complete each step individually. This is done in an interactive component. When the last step is finished and the user presses Send, I switch to the last variant which is a ‘completed’ variant. This variant is much shorter than each other variant (which all have a step opened). So I want to ‘scroll to the top of the component’. Currently I can’t do it so you will end up at the bottom of the page with the component completely out of view…
Phil_Larsen
Jan 3, 2024 11:35 PM UTC
Still encountering issues with this?
You might be able to accomplish it inside the component itself by using the “Reset Scroll Position” feature they added.
Anne13
Jan 9, 2024 9:25 AM UTC
Thanks for the suggestion Phil, but this doesn’t help. The interaction is within the component (it is an interactive component) and when I check ‘reset scroll position’ on the component interaction, it doesn’t help with resetting the scroll position in the parent screen that contains the instance.
Phil_Larsen
Jan 9, 2024 8:30 PM UTC
You might be able to achieve the result then by moving the scrollable part of the experience to the component itself and it is just housed in a parent frame for prototyping. Then, you would have more control of the vertical scroll of the elements inside.
