Phil_Larsen
Nov 10, 2021 10:09 PM UTC
Scroll to point in component
I regularly create components that allow for easy manipulation of prototypes at scale. I can’t, however, use the “Scroll” to prototyping feature on interior elements of a component. I need to break the component which then removes the benefits of having it as a component in the first place.
Could we get it so scrolling to an interior element of a component is an option?
Dec 10, 2021 10:10 PM UTC
Henning1
Apr 5, 2022 11:10 AM UTC
Hello Figma Community,
i am really new to figma. i am trying out my first prototype but stuck on my second day.
I build a sidebar component, where i can scroll the content and click some tabs to scroll down to the sidebar sections.
If i start the preview from the component it works as expected.
If i put the component to a page, where i will need it to use it more than once, i can scroll it, but the link interactions from the tabs don’t work anymore. (even the mousehand disappears)
Where is my fault? What did i forgot to check?
I would be happy if theres some help here.
Thanks a lot!!
Henning
Henning1
Apr 5, 2022 11:15 AM UTC
Took a video for better understanding
Mr_Wahoo
Apr 20, 2022 2:41 PM UTC
Yeah I have the same problem here 😕
I think it’s a bug when it comes to nested components…
If not, I’m really missing something
Bianca_Andrea_Duenas_Gomez
May 24, 2022 7:42 PM UTC
Yeah, I have the same problem 🥲 @Figma_Support helppppp us
Klesus
May 25, 2022 3:44 AM UTC
Figma Help Center
You can only scroll to top level objects.
When you try the sidebar on it’s own it works because the sidebar is the top level frame. As soon as you put it inside another frame, like when you put it inside the desktop frame, the sidebar is no longer the top level frame and scrolling stops working.
ntfromchicago
Sep 6, 2022 2:15 AM UTC
Please upvote! I am looking to reopen this previously closed request because I encountered this same issue recently. Scroll to point in component
This specific behavior feels like a bug because it allows you to create a component with scroll to triggers that worked before you make it a component – but then don’t work after you create it. It deliberately breaks all the links even though all the scrolling is encapsulated within the component itself.
I would rather have Figma tell me that a component cannot be created vs. creating it and not having the interactions work.
More importantly, fixing this would radically simplify some use cases where you have to make tons of variants to handle multi-state interactions. Simple scroll-to support would eliminate the need for so many variants (e.g. a large single-select radio button group).
Kevin_Simpson
Oct 27, 2022 12:41 PM UTC
This is particularly important for navigation. For instance, to create navigation to anchored links within a page, setting up scroll on a component is important so that you can use the same navigation across all of your screens.
See also the description of this problem here:
https://forum.figma.com/t/scroll-to-in-component-doesnt-work/19067
Minh_Quang
Nov 7, 2022 3:29 PM UTC
I have a component and set scroll to animation for that component. But it’s not working for the copies of that component. Any ideas?
Alexei
Dec 2, 2022 9:48 PM UTC
I have a wide layer and a button in the component which scrolls to the last hidden right column.
When I bring the instance on the page scrollTO doesn’t work and there is no way to reset it or make a new connection.
