eokic-hexis
May 18, 2021 4:51 PM UTC
Prevent interaction hotspots from triggering below fixed elements
    A scrollable (clickable) list of items triggers the interaction even if a fixed element overlaps it. Additionally, this bug occurs even if that overlaping element has a “Tap → None”
  2. Add as much context as possible (screenshots, Figma files, mockups, etc.)
    Stumbled upon this issue when I had to position an iOS keyboard on top of an interactive list of elements.
Demo file and steps to reproduce:
  1. Start the prototype from https://www.figma.com/file/GpbLNhQGrYKCTFO8aZy8BK/Hotspot-bug
  2. Click the gray bottom rectangle with or without scrolling
  3. It wrongly triggers the hotspot from the “background” items
Pinned Reply By djv
Hey All, thank you for your continued feedback!
The team confirmed that this is not a bug; it’s currently expected behavior. This was a design decision to ensure that frames without interactions do not block interactions. All of your existing prototypes with interactions actually rely on this behavior to function, so implementing what you would consider a “fix” would likely cause other major prototyping bugs.
Rest-assured, this is still being tracked as a feature request by the prototyping team to better understand how it is affecting the overall community. They’re now considering how to implement this in the best way that doesn’t cause other bugs.
We appreciate your patience and understanding.
Michalis_Panagiotidis
Jul 7, 2022 1:03 PM UTC
Yes this is soooo annoying! Unacceptable for a state of the art tool like Figma!
Joshua_Reach
Oct 13, 2022 5:00 PM UTC
It’s October and I’m having this issue as well. Clipping trick does not work for me either. This kind of needs to be fixed, badly. Has anyone found any other solutions?
Karolina_Trzesniewska
Oct 27, 2022 10:34 AM UTC
This bug is still persisting. None of the methods listed above worked for me at all, unfortunately.
Hg_Msnc
Jul 14, 2023 7:42 AM UTC
Same problem
Jul 15, 2023 1:22 AM UTC
I Have this same problem, very annoying
did you manage to solve it?
Jul 17, 2023 12:29 PM UTC
same problem, I have a fixed nav bar and users can always click through whatever is underneath, so annoying!!
Widd_Tom_ESI
Jul 26, 2023 7:37 AM UTC
Yes same problem with a FIXED or absolute positioned element seeming like its on a lower z-index than the scrolling (SCROLLS) item behind (below) it.
tank666
Jul 26, 2023 7:58 AM UTC
Nate_Greenwall
Sep 7, 2023 11:32 PM UTC
To get a button to not register under my header or bottom-nav element, I had to avoid using any fixed elements overlaying my scrollable content.
I put all my scrollable content within a clipped frame and turned on vertical scrolling. I then put that frame in between my header and bottom-nav.
