Prevent interaction hotspots from triggering below fixed elements
  • May 18, 2021
  • 54 replies
  • 6248 views
eokic-hexis
    A scrollable (clickable) list of items triggers the interaction even if a fixed element overlaps it. Additionally, this bug occurs even if that overlaping element has a “Tap → None”
  2. Add as much context as possible (screenshots, Figma files, mockups, etc.)
    Stumbled upon this issue when I had to position an iOS keyboard on top of an interactive list of elements.
Demo file and steps to reproduce:
  1. Start the prototype from https://www.figma.com/file/GpbLNhQGrYKCTFO8aZy8BK/Hotspot-bug
  2. Click the gray bottom rectangle with or without scrolling
  3. It wrongly triggers the hotspot from the “background” items
June 24, 2025
Hey All, thank you for your continued feedback!
The team confirmed that this is not a bug; it’s currently expected behavior. This was a design decision to ensure that frames without interactions do not block interactions. All of your existing prototypes with interactions actually rely on this behavior to function, so implementing what you would consider a “fix” would likely cause other major prototyping bugs.
Rest-assured, this is still being tracked as a feature request by the prototyping team to better understand how it is affecting the overall community. They’re now considering how to implement this in the best way that doesn’t cause other bugs.
We appreciate your patience and understanding.
Fabrice
  • September 2, 2021
I came across the same issue. Looks like it is a bug.
Workaround: Select your scrolling area frame and enable Clip content. Worked for me.
But obviously, the mere fact that your content layer is already under your keyboard layer should auto-clip in my opinion…
TinyLittleMaggie
I also came across the same issue while creating a navigation bar on top of a scrollable list of items!
Clipping content doesn’t seem to work for me? I managed to work around it by expanding all the navigation items to fill up the entire nav bar, so that there is no way to click on any “gaps” and accidentally reach the background items.
Definitely looks like a bug worth addressing soon!
Tony_Ritrivi_Tony_s_NASA_Googl
I am working on a web site prototype which we are allowing users to evaluate. Figma does not mimic normal browser behavior which will cause confusion during testing. Links on the page content area are still clickable even if the sub-menu overlays them. In the prototype link below, mouse-over the “Find Data” item… the links in the left menu are still clickable even though the menu is covering them.
Figma – 20 Aug 21
Is this a bug? Shouldn’t links that are below a layer NOT be clickable?
Michael_Michael
When a button or link has other layers on top of it, essentially hiding it from view, any on-click interactions assigned to it still work. It seems like Figma will bubble down the layers and trigger the interaction, even though the button is not visible.
Is there any way to prevent interactions from triggering, if the button/link is covered by another layer? Basically, the same way it works in real-world web design, where a link wont work if it has another element on top of it.
Adam_Ratcliffe
How do you have it such that interactive components are not clickable when there is something else on top/in front of them? ie in a mobile slide out menu i can still interact with components from the blurred out home page
Dave_Knight
Seeing this issue too. Workaround not fixing it for me.
Jedd
  • March 6, 2022
Okay, I think I figured this out, after hours of trying.
First of all, you have to make sure you have Overflow Scrolling and Clip Content turned OFF on your master frame.
Then, all of your scrollable content should be in a nested frame with Overflow Scrolling and Clip Content turned on.
Last, it seemed kind of hit or miss for me as I was making these changes, but I think closing out my project and reopening once all was said and done seemed to help. I think Figma needed a hard refresh to recognize these changes.
At least, it’s working for me now! fingers crossed
Hope that helps.
Rich_O_Brien
Seeing this issue across all my prototypes too… Unfortunately the clipping trick above didn’t work. An update on this would be awesome.
Jessica11
  • April 22, 2022
Yes I’m having this issue as well. It’s a pretty basic function, having a fixed nav over a list of items that are clickable. I’ve created boxes in the nav to ensure there’s no clickable space, but still. This is quite annoying.
McKinley
  • June 16, 2022
Still seeing this bug. Anything that is clickable that gets scrolled underneath the fixed content (the top nav) is STILL clickable through the top nav. Extremely annoying.
Michalis_Panagiotidis
Yes this is soooo annoying! Unacceptable for a state of the art tool like Figma!
Joshua_Reach
  • October 13, 2022
It’s October and I’m having this issue as well. Clipping trick does not work for me either. This kind of needs to be fixed, badly. Has anyone found any other solutions?
Karolina_Trzesniewska
This bug is still persisting. None of the methods listed above worked for me at all, unfortunately.
Hg_Msnc
  • July 14, 2023
Same problem
I Have this same problem, very annoying
did you manage to solve it?
same problem, I have a fixed nav bar and users can always click through whatever is underneath, so annoying!!
Widd_Tom_ESI
Yes same problem with a FIXED or absolute positioned element seeming like its on a lower z-index than the scrolling (SCROLLS) item behind (below) it.
tank666
  • July 26, 2023
Nate_Greenwall
To get a button to not register under my header or bottom-nav element, I had to avoid using any fixed elements overlaying my scrollable content.
I put all my scrollable content within a clipped frame and turned on vertical scrolling. I then put that frame in between my header and bottom-nav.
Do we have any fix for this? This issue is so annoying, I miss Adobe XD for simple things.
Michael55
  • October 20, 2023
How is this still a thing…
Bauke_Schildt
  • Active Member
  • October 23, 2023
This is a smart workaround, but this definitely shouldn’t have to be done just to have a fixed menu… And it doesn’t work if you want to have transparency in your menu.
Julia_Shlyapnikova
I keep experiencing the same problem.
Edyn_McCarty
Still looking for a fix to this too. Not sure how this hasn’t been patched yet.
