Aalok_Trivedi
Jan 29, 2021 6:26 PM UTC
Option to NOT create subfolders when exporting assets
It really annoys me that Figma automatically creates subfolders when you export an element that’s inside a component and has a ‘/’ naming convention. I always have to go back into the folder and delete the folders or rename everything. It would be great to have a simple checkbox toggle in the exports panel to enable/disable creating subfolders, similar to Illustrator.
10u15
Mar 1, 2022 7:20 AM UTC
Yes, no subfolders, and a system dialog to be able to name the file! So much time wasted to delete folders and rename files!
Warren3
May 11, 2022 2:21 PM UTC
Please fix this figma… can’t stand this behavior!
ileb
Aug 19, 2022 6:38 PM UTC
100% agreed…
Allan_Falcao_de_Oliveira
Sep 5, 2022 7:48 PM UTC
my life would be a lot better.
Figma_editor
Sep 15, 2022 2:57 PM UTC
Just don’t use slash
Katia_Baro
Nov 10, 2022 3:26 PM UTC
please Figma do it !
Ruby-HB
Nov 15, 2022 12:08 PM UTC
It would be sooo useful if there was an option to automatically replace the slash with a dash ‘-’ instead when exporting, so we wouldn’t have to rename everything in Finder afterwards!
Swapping the slash would be more useful because we have to use the slash within Figma to organise all the icons etc.
Dennis_Schmidt
Feb 17, 2023 4:25 PM UTC
Would be yo helpful.
Justin_Reese
Feb 23, 2023 4:51 PM UTC
Just ran into this behavior for the first time, and oof, was it unexpected. And at least in macOS, the system save dialog was very unfamiliar when in this “mode”, not letting me change the filename while saving for example.
If this is unintentional behavior (which I suspect), it should be fixed by sanitizing the filename before sending to the system save dialog. If this is intentional behavior, then there should either be a warning when using / in frame names (which sounds gross tbh) or the option to sanitize them away during export.
Because the current situation, where I just found out that my dozens of frames have problematic names, is… not fun!
Jacob12
Feb 24, 2023 10:18 PM UTC
I may have found a soft solution, or at least the cause of the bug. I notice that the frame I was editing in, “Search/view historical analyses”, had a “/” in it. I removed the forward slash, and when I went to export an asset in the frame it allowed me to name the file and didn’t create a subfolder. If I try to export assets in frames that have "/"s in the name, Figma will create a subfolder and remove naming options.
Seems like unintended behavior to me.
