Jason_Williams
Jan 27, 2021 3:18 PM UTC
LAUNCHED: Variables! (Design Token support in Figma)
We have been managing our design system(s) for Desktop, Mobile, and TV applications in Figma for some time now and the experience overall has been great (especially with the updated Auto-Layout model) but one thing that has been extremely difficult to manage are design tokens. When I say manage I actually mean we are not using them because there is no solution to do so between Figma and our actual developer component libraries (Apple TV, iOS, Android Mobile, Android TV, HTML TV, HTML Desktop, etc…). We would love to more widely support themes in our apps and at a minimum use tokens for colors, spacing, font weights, and more. This would not only dramatically help with design speed and consistency but allow developers to more easily translate the components and layouts to real platform components (if you could inspect or export the tokens).
Here are a few key items that are quite difficult without first party support for tokens.
  • Color Themes: Without tokens you have to rely on color styles which have a few issues. One the alpha is part of the style so assigning a color style to an auto-layout background requires you to have a color for every alpha variation you may have (ie: modal overlays). We have written a plugin to replace theme colors with another theme but this is a bit of a hack and again can only replace the entire rgba set instead of just the color without affecting alpha. With design tokens and a few UI tweaks this would all go away.
  • Font Styles: Today, Type styles comprise font, weight, line-spacing, etc… which in general is great but if you want a bold, italic, or weight variation you have to create a style for every variant. This would be much more efficient with with tokens (ie. font-face-body, font-face-heading)
  • Spacing: While auto layout is amazing it would be so much better with paddings and gaps being able to be set via token. Today if you decide you want to change the standard gap between list items or card row items you will find yourself drilling down through a lot of components and manually updating pixel values. How much nicer would it be to change the spacing-s token and see everything update! I know some people use spacers but they just muddy design layers and with create so much complexity when auto-layout already supports individual paddings for T,R,B,L. The other issue here is that while you will have a component library the designs that use that library often use frame specific auto-layouts to compose them into the design. This means there is no downstream update to those designs if I want to change the standard margins on the left and right of our designs. Each and every frame (app view) has to be updated. For us that could be hundreds. If the tokens were part of the shared library (like styles) then designers would just use a spacing tokens downstream when laying out a page. This allows me to update the design system and as designers accept the changes in other files the spacing (margins) in this example would just update.
  • Developer handoff: By not having first party support for design tokens the only thing shown in in the inspect window for developers are styles and pixel values. It would be so nice if designers could export JSON and/or CSS variable code that defines the token model to provide developers (or let the developer download / copy them). Then in the inspect window the developer could see the tokens used for colors, padding, and so on.
I know there are plugins out there that attempt to help with this but they are just to fragile because the plugin system does not support modification of the actual Figma UI (which I think is a good thing). However, considering how important tokens are to modern UI design and component development, I feel like this may be something the Figma team is best suited to address.
Here are some quick and dirty mocks on implementation thoughts, based on the current UI. These are just meant to be thought starters so take it with a grain of salt. But I would love to hear what other think. Do others want this feature as well? Are you REALLY wishing we had design token support? Figma team, is there anything on the roadmap for something like this?
Vanessa1
Apr 8, 2021 7:55 AM UTC
When I’m working with Figma and create a prototype, I often have values that are repeating like a consistent padding/margin, a consistent drop shadow or border-radius for different components and many more. When I want to change it, I have to change it in various places. It would be cool if there was an option to bundle this in variables (like it’s already possible with colours)
Do you also run into those effort-high changes?
Jason_Williams
Apr 29, 2021 10:30 PM UTC
That is great news. Thanks for the info!
Lucas
May 5, 2021 12:56 PM UTC
Any update on this? Theme-able design systems are a must-have for my team and the current implementation of styles makes this very painful (borderline impossible). Plugins are buggy and can only take us so far. Thanks for all the hard work! 😀
Adam_Polyak
May 23, 2021 5:44 PM UTC
I have a design system that I use as a starting point to build up UIs for my clients.
My design library is based on atomic design and I benefit a lot from my systematic approach of using the same tokens across the whole library.
So the usual process for me is to decide what corner radius I will use to match my client’s style, decide on line weights for the borders etc.
Now it is a lot of work to override these values one by one for each component.
If I could create tokens and build units in Figma my job would be easier and quicker.
I imagine a similar process as to how you can maintain a type and color system.
(Also it is useful when my client asks for a change in these tokens. I could even quickly show them the difference between different options on the fly.)
Grant_Novey
May 25, 2021 3:18 PM UTC
Have you tried using a plugin for this? Here’s one: Figma - Figma Tokens | Design tokens are an integral part of any design system, with Figma Tokens you can reference valu...
I would love for this to be supported natively in Figma. Fingers crossed it will come in a future update.
Adam_Polyak
May 26, 2021 9:50 AM UTC
This is awesome, thanks a lot @Grant_Novey !
Yes I agree, a native support for this would be the optimal solution.
Yesteday I watched some Figma streams on Design Systems and there were mentions about this feature. So yeah, fingers crossed!
Dean_Wong
Jun 2, 2021 8:07 PM UTC
This post is great, throwing in $.02 as a feature request. Definitely hits on where we’re also hampered in advancing our Design System. Real Design Tokens, that would allow styles to drive other styles, would help reduce the likelihood/potential for bloat in splaying out a lot of options, aka what variants did for components, having these would help immensely at the Atomic level to support multi-brand/omni-channel initiatives. It also would better match our user’s workflows to have a baseline color palette that drives usage-specific variants. Does Figma have any plans to put this feature on the roadmap this year?
Lucas
Jun 3, 2021 1:05 PM UTC
…would help reduce the likelihood/potential for bloat in splaying out a lot of options, aka what variants did for components
@Dean_Wong This sums up the need perfectly 💯 💯 💯
Koen_van_Niekerk
Jun 5, 2021 7:19 PM UTC
Would indeed be a game-changer.
It would be nice to also be able to switch between different token-sets (As the Figma tokens plugin does)
vdekkernl
Jun 9, 2021 3:15 PM UTC
Agree, the gap between front-end and design tool must be closed. @figma we need to define master unit (1 rem) and use it for font-size, line-height, paragraph spacing, auto layout padding, spacing.
