Jairo
May 19, 2021
Interactive components not working when nested inside a main component
  • May 19, 2021
  • 79 replies
  • 26998 views
Hello, I found out that if i create an interactive component (ex: Button), and place it inside a a main component (obsiously as an instance), the interactions are no longer working.
But if you create an instance of the parent component, then it all works as expected.
Jordan_Romanoff
May 21, 2021
I ran into the same thing. It looks like a click interaction (on click, mouse down, mouse up, while pressing) will work, but mouse enter / mouse leave / while hovering doesn’t.
ChiSenires
May 25, 2021
Same issue here. I have a dropdown interactive component with the expanded and collapsed state as variants, then I have an instance of that in another component. I initially joined the beta to see if this would solve this, but I guess there are still some bugs to fix 😕
Chi
Steve_Markovich
June 4, 2021
Partial interaction working for me. I have a button nested in parent component. The mouse-in state triggers, but mouse-leave and on-click are not working. Button component stays in its hover state until I restart the animation with a refresh, etc.
Nicholas1
July 5, 2021
Hi, I think I have a related problem. I created an interactive checkbox with two states. However, when I add it to any layer, the “change to” interaction does not work.
I added the checkbox by dragging the component form the assets tab.
Pretty new to the software and UI Design in generell, so very thankful for any advice.
josealvarezn
Same issue here, I noticed that since day one of the beta.
Dante_Qode
August 26, 2021
please fix this 💚
Vinther_Line_Dausel_ELS-AAL
September 6, 2021
Have the same issue, i’m glad I finally realised it wasn’t just me.
This is a an important one to fix. Building a larger library of components this is a must have!
Aiden_Zucker
September 15, 2021
I’m having the same problem. The workaround I found it to break the parent component and paste it onto every frame of the prototype…which is quite time-consuming 😛
J_Yun1
September 15, 2021
If there was a multi-state feature within an element, this entire problem would be solved.
Cris_Gonzalez
October 26, 2021
I’m having the same issue! Any news given that today interactive components went public?
