Jairo
May 19, 2021 7:39 AM UTC
Interactive components not working when nested inside a main component
Hello, I found out that if i create an interactive component (ex: Button), and place it inside a a main component (obsiously as an instance), the interactions are no longer working.
But if you create an instance of the parent component, then it all works as expected.
fernandolins_cs
Dec 30, 2021 4:51 PM UTC
Thank you for this detailed reply!
KVP_Roope
Jan 4, 2022 10:46 AM UTC
Thanks, Kevin, this workaround works.
Ricardo_Andres
Apr 15, 2022 8:38 AM UTC
Hey @Anastasia_Stallcop, thanks for your comment. It looks like it is the right way to go. In my case, however, the combined components (variants) never worked on the page I have the components. What I had to do was to duplicate the design page where I had the issue and then it worked. I am happy I found a way to fix the issue but the fact that I dont understand why it doest not work really annoys me
Jairo
JairoAuthor
May 9, 2022 5:59 AM UTC
It is been a while since i started this topic, and at this moment my workflow switched around this problem.
Main thing i understood is that there is no much reason to use main components in your production pages.
In my average wroflow. i created components nested with other components as needed, and then store them in pages following the Atomic Design theory.
Then i grab instances of whatever i need and use them in the layout pages (where i put all the pieces of the screen toghether)
That way i make sure everything is an instance (so main components are safe), and also that everything is interactive.
It also helps into some popular interaction bugs, but that is for another topic.
But to put a solution on this topic: “For some reason, no, Interactive instances does not work inside a main component. They work when the main component is an instance as well. Try figuring out another workflow, that not requires main components to be inside production pages. (which in my oipinion is also a bit dangerous)”
McKinley
May 9, 2022 9:05 PM UTC
This issue has not been solved. I created an auto layout that expands out. This works fine on its own and also when I turn it into a component. As soon as I create an instance of that component, the interaction of the expanding auto layout DOES NOT WORK. This bug has been around for a really long time apparently and it’s still not fixed??
marcelg
May 10, 2022 8:20 AM UTC
this is really annoying. please fix.
Jairo
JairoAuthor
May 10, 2022 2:31 PM UTC
example file?
marcelg
May 12, 2022 9:31 AM UTC
https://file.io/6Nk9xO5gjn5o
sample file that shows the bug
open overlay doesnt work in variant2, when opened
marcelg
May 12, 2022 9:37 AM UTC
FileTransfer.io
other file host
Iris_Wood
May 29, 2022 11:21 PM UTC
The solution doesn’t work for me. I’m still having this problem when trying to apply interactions to nested instances? My product card is an instance of a component with 8 variants and instances of components inside it, like buttons etc.
I can’t set the “change to” interaction on those buttons unless I detach them inside the card component - you can see in the GIF it won’t accept any changes to the properties, it just instantly reverts back to its original state
May-30-2022 11-19-00
