Arvid
Feb 19, 2021 6:15 PM UTC
Inspect a version history file
I want to share a certain point from the version history with developers so they have a finished version they can inspect while I work on a new version. However, while I can find where I can copy and share the link of a restore point in the version history, when others view them, they cannot switch to “inspect” to see the version history.
Power Member
Feb 20, 2021 1:32 AM UTC
I changed your topic to #product-ideas as it is not possible now.
Rudel
Jul 5, 2021 9:08 AM UTC
Hi, Arvid, you can duplicate version history to a separate file and then share it with developers.
Arvid
ArvidAuthor
Jul 6, 2021 3:53 PM UTC
Hi Rudel,
yes, however it is a bit inconvenient to create multiple files and can lead to confusion amongst devs as well as to what the current source of truth is which I would still very much like to see it implemented directly in the version history.
But, yes, as a workaround this works. Thanks!
tank666
Jul 6, 2021 5:36 PM UTC
Hi @Arvid, if you have an Organization’s plan, you can participate in beta testing branches. Thus, you can work on a new version in one branch, and send a link to Main to the developers.
https://help.figma.com/hc/en-us/articles/360063144053-Create-branches-and-merge-changes
Martin_Sotzen1
Aug 11, 2022 2:49 PM UTC
even if there is now the branching feature, it would definitely still make sense if you could link a version as dev handover and inspecting would be still possible
Fabrice
Sep 5, 2022 6:46 AM UTC
My (readonly) devs too want to be able to see previous versions of the file (“we want to check how this dialog was before…”). What’s the rationale for stopping them from a viewing a particular version, given that they can edit anyway, what can go wrong?
Fabrice
Sep 5, 2022 6:51 AM UTC
Perhaps the need is to control how much of the history the guest (your devs) can see, versus which versions you want to hide from them?
Philip_Mattha1
Jan 4, 2023 11:50 AM UTC
Yeah, for my team this would be very helpful as well. I think it is a simple UI thing, that While I am looking at a version History I mandatory select the “Hand”-Tool, with that I can not inspect. and has the Inspect and Version History are on the same location, only one can be shown at the time.
An idea would be to include Version History as a Tab on the right panel. Then you could switch between inspect and Version History.
Lino_Ramirez
Jan 12, 2023 10:05 PM UTC
I also don’t understand why, Figma’s clearly loading everything so at the very least let us inspect it directly without the illy workarounds of branches or duplicates. The whole point is to want access to something “frozen in time”.
Drew_Kimrey
Mar 1, 2023 9:08 PM UTC
Chiming in again here. For my team this would help us establish trust with our development team and save us process around multiple files
