megaroeny
Aug 19, 2021 7:37 PM UTC
Finding Missing Library components/styles
First off, I’m loving the new Swap Library feature!
Problem
Today, it actually helped me discover some “rogue” styles and components that were leftover from an old library! Now I can try to locate those and finally get rid of them in our current library!
But wait - what if I don’t actually know where these are in the file? Or even further, what if I can’t get Figma to find a match?
Suggestions:
  1. The one thing I wish this feature could do is to help me actually locate those rogue styles or components. I tried using the Instance Finder plugin but it still didn’t help because I have to actually locate them on the canvas/file first. ☹
  2. What if the dialog let us force a new style or component match, instead of us running into a dead-end with the None found message. Currently, it tries to match using the name. But that might not always work (like in this case.)
Any ideas are appreciated. Otherwise, wanted to pass this suggestion on to the Figma team. Thanks!
Julia_Shlyapnikova
Sep 7, 2021 6:59 AM UTC
Same issue. Cannot find any of the ‘missing’ styles. I’ve checked everything: hidden layers, unions and subtracts, I’ve managed to reduce the number of the the ghosts, but still have some, and it drives me crazy.
Danny_Marsh
Sep 8, 2021 9:34 PM UTC
I am also getting some cases where a match is found. Yet when I click Swap library the old style persists.
megaroeny
megaroenyAuthor
Sep 8, 2021 11:10 PM UTC
What’s interesting for me, is my missing library has similar names of styles or components (not exact) to my active/current library. Yet it won’t let me swap them (the option is disabled.) 😞
Pete_Lada
Sep 21, 2021 6:36 PM UTC
This is a hack, but I was having a ton of trouble finding some rogue styles that were missing. They didn’t show up with any plugins. I was able to find them by running:
figma.currentPage.findAll(n => {
    var style = figma.getStyleById(n.effectStyleId);
    if (style) {
        console.log(style.name)
        if (style.name === "[ style name you're looking for]") {
            figma.currentPage.selection = [n];
in console on each page. As long as you know the style name you should be able to find the layers this way.
You can do this with text styles, fill styles, effect styles, etc
megaroeny
megaroenyAuthor
Sep 22, 2021 3:56 PM UTC
Oh, cool! I will definitely try this out. Always fun to fiddle with the console (when you know how 😄 )
Update: @Pete_Lada I tried it out but appears to get no results? This is what I see:
for this:
Pete_Lada
Sep 22, 2021 4:11 PM UTC
Are you sure its an effect style? Like is this a fill style (color?)
megaroeny
megaroenyAuthor
Sep 22, 2021 6:02 PM UTC
Oh!! 🤔 Good question. Maybe what I’m seeing (in the screenshot above) is actually an Effect style? Is that what you’re asking?
If it is an Effect, can I change the code snippet to find effects instead of fills?
Pete_Lada
Sep 22, 2021 6:17 PM UTC
The snippet you linked is specifically looking for effect style names. You can change that bit to fillStyleId or textStyleId to find the names of those style types instead
megaroeny
megaroenyAuthor
Sep 22, 2021 7:46 PM UTC
Ohhhh! I see what you mean, thanks for pointing that out. Appreciate it.
Brendan_Tobin
Oct 5, 2021 3:10 PM UTC
As a workaround, Style Organiser helps to locate linked styles on the board. This is particularly good if your Library is made of local components, as remote styles are highlighted.
The plugin is Style Organiser (by SHOPEE SINGAPORE PRIVATE LIMITED)
