eokic-hexis
May 5, 2021 12:22 AM UTC
Figma prototype UI obscuring fixed website header
    Screenshot and sample file below. I’m using an iMac sized frame with extended height. This issue is exacerbated by the fact that this is the now the default view when using multiple flow starting points and is the only way to actually change the flow starting point. So you have a constant trade-off of whether you want to see the Figma controls or your prototype’s. Annoying as hell.
EDIT: When sidebar is hidden, the fixed header is visible but inaccessible. As soon as the cursor hovers near it, the Figma UI appears over the (clickable) website header. Wow…
  1. Add as much context as possible (screenshots, Figma files, mockups, etc.)
    https://www.figma.com/file/WlYbWyHwtBGEFZihdMt2az/Bug-Obscured-fixed-header?node-id=0%3A1
George_Christou
Mar 9, 2022 6:53 AM UTC
+1 for this, it’s not client friendly at all!
Kevin_Lehtla
Mar 31, 2022 6:34 PM UTC
Bumping this post up as well, as this is something that I have to create a workaround in every design by making a empty space in the top of the artboard which is stupid.
Instead why not just with un-hidden UI lower the design by the pixels of the UI and when Figma UI is enabled push it back up again. It’s not that hard to fix it.
Dan_Lutger
Apr 5, 2022 9:28 PM UTC
+1 Prototypes are mostly for others, not me. This is a really bad issue for me. I often am not sure where the shared link will end up so I cannot explain how to work around this to anyone that lands in a prototype.
My hack: Create a 64px black (or brand/instructional) banner at the top of your frames and make every page in the prototype the exact same height since Figma aligns pages to the middle of the browser window instead of to the top.
Orlando
Apr 6, 2022 12:50 AM UTC
Disappointed to see that this issue was brought up back in July 2021, and hasn’t been resolved. Maybe in our lifetime.
In the meantime, I moved all of the page content down enough to clear the Figma UI area. Then added a black bar going across and check the “Fix position when scrolling” option.
That seem to work for now.
eokic-hexis
Apr 6, 2022 9:46 AM UTC
I lost respect for them personally as this was by far the most absurd example of not giving a crap. It’s something that:
a) impacts a very common usecase for their product
b) causes serious issues within the context of that usecase (non-tech-savvy clients are experiencing this)
c) should’ve never came up as an issue in the first place, which implies poor design decisions and/or QA
d) then they just ignore it for a year after being reported, while at the same time the fix for it is trivial, both in terms of design and technical complexity
This sort of crap is the exact same reason we dumped Sketch two years ago, so now I’m just disappointed by the idea that soon enough, Figma might be riddled with pointless QA issues…
Pernille_Saetre
Apr 19, 2022 10:43 AM UTC
This is a deal-breaker for using prototypes with clients. I need the sidebar visible so that clients can access the different tasks of the user testing easily, therefor hiding the UI is not an option. Please fix this simple issue.
de_la_Puente_Pantoja_Alberto
Apr 22, 2022 8:41 AM UTC
Same problem here! 🙋‍♂️t4: I’ve been working since 2015 and didn’t realize how annoying this could be. Come on Figma fam I think we could have a better solution.
BTW I just found that you can share the prototype link without the UI by adding “&hide-ui=1”
Chris_Plowman
May 9, 2022 11:41 AM UTC
How has this not been fixed yet?! All we are asking it to adding some padding or margin to one element of the preview!
Currently having to send 4 separate links out to a client, so they can see without the header obscuring, when I could just send one and let them navigate through them themselves.
Jay_Am
May 11, 2022 1:53 AM UTC
Is it so hard to introduce a “fullscreen” feature in the prototype, enabled by a button in the UI? We talking about the globally leading application for developing user experience design here. Somehow I get the feeling they do it on purpose. It’s a big pain in presentations when designing in 1920x1080 (and presented on a screen with this resolution). The design is cut off in the bottom and we see the tabs in the top of the screen. Very confusing to users and frustrating to designers.
Jay_Am
May 11, 2022 1:58 AM UTC
…the shortcut command + backslash is a joke. The backslash is not accessible directly on the keyboard. One need to press shift + alt +7 for backslash. So how to do it?
