Zoltan_Szalay
Sep 22, 2022 1:44 PM UTC
Expose/hide nested instances -> at component property level
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure.
Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component.
What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
Brian_Heston
Oct 13, 2023 6:34 PM UTC
I can’t upvote this enough. The current component model forces many hacky workarounds to approach something usable, and at best there’s some other tradeoff or invalid configuration you’ve had to expose.
This is the root of most of these problems. We need to be able to compose larger components from smaller ones, while hiding some of the implementation details of the smaller ones. This include hiding properties, changing the “recommended” instance swaps, or even limiting the instance swaps allowed.
Domenico_Flauto1
Oct 16, 2023 4:21 PM UTC
Yes, please! 🙏
Torsten_Daeges
Oct 18, 2023 6:18 PM UTC
Our team is working on a new design system and it’d make things so much easier if there was a way to hide specific props of nested components depending on where they are used. Otherwise, the props panel can grow unwieldy pretty fast and it would make so much sense to tailor exposed props to the specific use case.
@Figma-Team: Could you share if you’re even considering such a feature? It would really help us to decide basic questions regarding our component structure. Thank you!
Mat_Wennergren
Oct 30, 2023 10:32 PM UTC
+1 YES 1000 Times!
Daniel_Amann
Nov 3, 2023 8:18 AM UTC
+1 This is critical to avoid overwhelming designers with too much irrelevant choice
mikebusby
Nov 3, 2023 6:35 PM UTC
This is an absolute necessity. Figma really needs to prioritize this feature.
jimmykl
Nov 9, 2023 2:39 AM UTC
💯 Everything already said 324x ☝️
Rocky
Nov 9, 2023 4:42 AM UTC
Hell yes to this
Bhavin_K_Padhiyar
Nov 9, 2023 9:34 AM UTC
It’s must fix the issue. Long-due request.
Michael_Thomson
Nov 10, 2023 9:41 AM UTC
We are also building out of design system, and I can concur that this would be super helpful to make the components easier to use and handle when creating mocks.
It could be as simple as a eye toggle so you can choose what to hide and what to show.
