Zoltan_Szalay
Sep 22, 2022 1:44 PM UTC
Expose/hide nested instances -> at component property level
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure.
Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component.
What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
Soraya_Meystre1
Jan 3, 2024 10:41 AM UTC
Need this as well !
Jon_Duncan
Jan 6, 2024 6:02 AM UTC
I will piggyback on this and say I have definitely found a need for this within our system. For example, Have a core navigation component created for my team.
Some properties are pre-defined and should be the same across all instances (ex. Menu Item A should always have “Show Right Icon” on because it’s a link). I need the ability to lock or hide, since team members should not be able to override this decision.
However, in the same component, there are properties that my team should have control over, such as changing Menu Item A from “Unselected” to “Selected”
Elaine_Cervania1
Jan 9, 2024 8:46 AM UTC
Keeping this open because I need this too on our design system…Hi Figma!
Jan 10, 2024 11:43 AM UTC
+1, is really needed!
MADELIN_ARIELA_ERAZO_DIAZ
+1, we need this.
Jan 15, 2024 3:58 PM UTC
+1 Needed over here too
Bart_Vlaemynck_Belfius
Jan 17, 2024 4:25 PM UTC
+1 Really need this
Jan 17, 2024 8:24 PM UTC
I also need this feature. My customer designers get overwhelmed by all of the options some of my larger components have.
I also have trouble where large components that are composed of smaller ones will have identical properties at multiple levels. All parts of complex components all need to be set to the same platform (“Mobile”), for example. It is necessary for me to hide those platform options at the lower levels, even if I need other properties exposed at those levels.
It is too easy for one of those to get out of synch at the wrong level, which screws up the component.
Ryan_Leichty
Jan 20, 2024 8:54 PM UTC
Please oh please!
Viktor_Ostrom_Berg
Jan 22, 2024 10:43 AM UTC
We also need this functionality in our designsystem. One example is our Icons where user chooses Icon by typing its name so the name property needs to be exposed, but the other properties (size, strong, active) is not allowed to set.
Another feature that would solve this is the option to pass down property values from the top component to nested components. In that case we’d simply have an Icon name property on the top component that is passed down to the Icon component (very similar to how it would be coded in React for instance).
